on my t5 i put duct tape over then foil tape over that then carpet its still ok 4 year later
Thanks mate, if you don’t mind that would be great. At least that way I can price them up and either buy or rule them out! I just need the passenger side number. (Driver side has a full height ply panel.)It was my van in the pic - if you want me to pull the trims to get the code off the back let me know.
You could always sikaflex a bit of something in to bridge the opening. I remember someone saying to tape over all the holes in the metalwork as dust blew through and marked the (light coloured) carpet.
Thanks mate, I’ll get them priced up!Here is a pic of the D pillar trims from my swb, which are handed. They are not going to push on over the top of carpet!!
Hi Mark, I copied this for the previous thread, hope this helps...Were you able to find the part number for the LWB? I am tempted to cut some ply to fit as I would like to have access to the holes if i can for cables, the issue would be sorting a fixing kit for it as well.
Genuine VW part to clip into the holes in the 'D' pillar of a LWB T5 or T6...
7H3 853 215 Y20 I think the only colour option is Y20 pearl grey but check number and colour when ordering. There are 6 per vehicle i. e. not handed.
I always fit them, could be fitted with a round air vent, I used vents from REIMO but I can't find a part number for you now.
Rod
That’s a good number, I used them on my van and put them in after the carpet so I could get access to the pillars. There are some photos on my build thread I think it looks OK.Hi Mark, I copied this for the previous thread, hope this helps...
