8 Hours or less! (Unless your mechanic has no tools)Thanks Loz, are we looking at say 8 days or less?
Is it still under warranty?Thanks Loz, turns out York Commercial can see to my van.....in 5 weeks! Now have to get car, caravan and us home to Newcastle ! Seriously considering Mayday @ green flag
Call VW assist, if they can't fix it they can get a priority booking at the dealer.Hi Loz, yes its under warranty 21 plate
York commercial is trying their best to be the worst dealership in Britain; they get my vote; I live within walking distance of them but travel 40miles for dealership service etc.Thanks Loz, turns out York Commercial can see to my van.....in 5 weeks! Now have to get car, caravan and us home to Newcastle ! Seriously considering Mayday @ green flag
The timing belt has nothing to do with the alternator, its the aux belt you mean.Ask for a new timing belt to be fitted at the same time as the alternator is replaced, they can only charge you for the parts as the Timing belt has to come off to do the alternator (money-saving tip)
they won’t want to do it because they will want to catch you with the full cost later on it but insist it is done, particularly if the alternator has failed.
don’t settle for the “we'll visually inspect it” BS
Still great advice!you are correct and re reading my post i did not make it clear, and it is misleading.
the Aux belt drives the alternator, but it is in very close proximity to the Timing belt, despite the redesign of the guarding, there are still several potential issues that can affect the timing belt when an alternator fails. depending on the type of failure, (which it’s unlikely the OP will be told, by VW).
The aux belt could be damaged, pieces of a damaged serpentine belt can manage to get into the timing belt mechanism, even with the redesigned guarding, causing potential damage to the Timing belt, if the investigation Job is done properly they should remove the timing belt cover to check it fully for signs of damage, purely because the consequence of damage to the Timing belt (from the alternator failing) could be catastrophic.
Also Depending on the type of alternator failure, it it were electrical, it may have caused excessive heat local to the timing belt, which may damage the belt construction which may not be detectable on a visual inspection, excess heat can can cause premature failure of the timing belt.
Hence my comment regarding “Visual check“ of timing belt being BS, i.e. the part that failed (alternator) is relatively cheap to fix but the failure has the potential to affect the integrity of the timing belt, with far greater consequence & cost should the investigation and remedial measures not be carried out correctly.
if it were me I would be having that discussion with the VW garage regarding the sanity of a visual check of the timing belt (particularly when you refer to VWCV maintenance period, they obviously think these belts can’t last more than 4 years without being a severe risk, regardless of mileage)
VW can’t have it both ways !
But the timing belt doesn't have to come off to replace an alternator, though?you are correct and re reading my post i did not make it clear, and it is misleading.
