How to disable 2015 T6 interior sensors
To verify switch operation (T6) with OBDeleven:
Control Units > 09-Central Electrics > Live data > Channel 17 - Value 3 shows either not operated or actvated (when switch operated).​
To confirm you're doing right thing back up (left arrow down left) to channel 15 - press your keyFOB and look into "Value 1"
Should I be doing this while in the van with the ignition on @mmi ?
This is what I see.
When I press the interior alarm disable button nothing changes although the ignition is still in as it has to be for the dongle to read the data.
When I press the key fob i get this shown on channel 15.
Reactions: mmi
Good - I mean the OBDeleven is doing right thing - reading the data. Looks like there is disconnect with the switch (I believe the status is the same with/without ignition on).
However, just verified that OBDeleven does read the data even ignition OFF (and driver's door open for this case). Just takes a little while to connect.
Did the following (IGN OFF, driver door open!!!):
Plugged in the dongle, launched OBDeleven​
Takes a while to get message "Make sure ignition is on", Continue, Select the vehicle...............(eventually "Connected")​
Click Button = down right​
Control Units, 09.......... Loading data........... Live data....​
If I press the interior sensor switch with the drivers door open this is what is shown on channel 17. Now I am lost.
I think I may have a bad connection behind the B I’ll at as it just went amber and on locking the van only heard a single. However I have been unable to replicate this.
Reactions: mmi
But that's good - the BCM recognises the switch is operated :waving:right?
Yeah true, it’s got to be a bad connection somewhere as the switch is basic.
Reactions: mmi
yea, I was annoyed by the change in coding that changed this.
I wanted the ability to disable the sensors when the roof is up and windows open a bit but still have deadlocking that the button alone used to provide.
press the closed pad lock button on the drivers door just above the wing mirror knob , locks doors and omits movement sensor, i to kept setting the alarm off
No good from the outside when you leave it to go to the pub.
