Just back from the hunter alignment and heres the print out. Pov appreciated.View attachment 47263
adjustable polybushes should get your camber in the green or very close
I bet it drives much smoother though
To be fair it drove ok before i had this done. What will the poly bushes give me?.
Is that summat i "need" to adjust?
Are you able to send me the settings for Hunter via what’s app as I’ve had SoLows fitted and wouldn’t mind getting it done?Any Hunter place will be fine, if they allow you to dictate the settings, and you follow the sweet spot now discovered for lowered T6s, which I can shoot over to you on WhatsApp.
You just need to find out if the engineers will do this, because I suspect some won't, because it means overriding the Hunter system.
Had my alignment done yesterday at drury lane services in chadderton. Stewart is a cracking bloke and did exactly what i asked for after showing him the info i got from @Tourershine. Great service and i cant recommend them enough. Mention my name (mark with the shuttle) and he will look after you.
I'm on 20s and 40mm lower and think I'll visit DruryLane. Will Stewart know the settings ? Or should I get them from Tourershine ?
thanks
s
Interesting. Is it worth a trip from Manchester (when allowed)? Did he make many adjustments? And finally, how low are you? CheersTo be fair since replacing the tyres I've not done enough miles to notice any tyre wear yet. After replacing my tyres and doing some more adjustments to my suspension I've had it on another hunter machine at a company called Tuned uk in wrexham. This is because hes located not too far from my caravan and after doing some research,richard the guy who owns the company looks after a few touring car teams. After he tweaked my alignment he told me to put a few miles on it and come back and we will look at it again but due to lockdown etc I've not been able to. He did say because im running low i may need to change to adjustable bushes on the rear but i think im just gonna change em anyway.
Thanks I’m was wondering if it was worth driving from Manchester to Wrexham rather than use the Oldham place. is there a typo in the last sentence? CheersAll i had done at tuned uk at the minute is the alignment. Il measure in a bit how low i am. Its roughly about an hour away from me and about 40 mins from my caravan so was ideal for me and hes a nice guy and knows what hes doing. From the wheel arch to the wheel rim closest the floor is 60mm.
