I think I need Wheel spacers
D9emp
Anyone got rear wheel spacer on fully converted? Van is currently lowered but the front looks wider than the rear so want to bring it out a little. Any pics and what size spacer used be awesome
All depends on the offset and size of your wheel. There is loads of room in the rear arch so you will have plenty of scope to space it out dependant on size.
A 20” is normally a standard offset of around et40-45. You should be able to get a 10-15mm spacer on that. Be better if you can confirm the ET first.
Even a 10mm spacer will make all the difference looks wise.
HTH
HTH
Oli, Does fitting spacers affect alignment at all or are they 'fit and go'? I'm considering fitting 15mm on my rear standard VW 17" steelies (which I'm changing to 18" in a few weeks).
Jumping in on this. Have you ever fitted spacers to a van with a Loc 8 table or Kirivan door store Oli? I have a twin slider and was considering spacers but there doesn't appear to be much room. Currently running OEM 20 inch sport line wheels.
I run 30mm rear and 20mm front spacers on a Caravelle which has door cards of comparable thickness to Kiravan door store. Depending on exact wheels and tyre speare not I'd have thought 15mm rear spacers would be fine.
Cheers. I'm using 20" tridents with 265/40/20 tyres. There doesn't seem to be an awful lot of room as you mention tbh. @BognorMotors have you experienced spacing out tridents before?
Yes we’ve spaced them out but without knowing the exact dimension or seeing your door card it would be hard to say what will work.
