Edge of floor bracket trim to door card lining 210mm - photo1
Floor to underside metal seat tube 175-180mm -photo 2
Distance between outer of the two floor fixing bracket trims 600mm - photo 3
Photos are a bit sh*t, because A it's dark and B because my lovely iphone 7 fell out my pocket today when cycling and a car ran over it, do back to an old iPhone for 18months, grrrr!!!
270mm from floor to underside of seat. Dimension 3 would be 400mm, the front of the box would then line up the the front edge of the front seat bracket trim.
A nice 300RMS 2 ohm job, can get it into a sealed enclosure within the sized identified (just). the whole needs to be just over 9 inches so a 10.5 inch box will be ok.
I was looing at a nice little Focal amp before but its 350w RMS at 2 ohm, I just know I'll end up pumping the sub with it so on the hunt to match the 300w RMS spec that way I know I will be safe.
Front focal components
Rear focal coax
Sound deadening front doors
Pods for rear speakers
Harness
Wiring kits
Sub
Amp
Remote eq
Speakon for side panel
Wading for inside box
Acoustic carpet
Looking forward to this now, just need to decide where I'm going to put the remote eq!
