It can make sense yes but it tends to be a feature of more advanced installs.
The installed way of doing it is to have a dual charger unit, or you can get trickle charge diodes.
Changing the whole charger would probably be very disruptive for you and not worth it.
The trickle charge approach is mostly to stop the self discharge of the starter battery if you use the van less frequently but have solar/EHU when parked at home, and that doesn't sound like how you use your van but they are small and you may be able to fit one.
A third DIY way you could do right now is to get a simple maintenance charger from someone like CTEK or NoCo and a cigarette lighter adapter. Then you plug the charger into a van mains socket when you are on EHU and plug the other end into the permanent live dash 12v socket.
Several threads on all three approaches around the forum.
