Ignition Fuse Box
Tezzzhead
Hello
I'm trying to fing an ignition live under the dash board. I've read that the center fuse board is all ignition live under the dash by the passenger side.
So I've wired up my ctek and am getting 11.7 volts out of all of the fuse holes that are spare. Is that right?
11.7 volts when off? I thought it should be 0 volts lol when ignition is off.
Any help would be much appreciated.
Thankyou.
I am fitting a dash cam but am having trouble finding a live lead when the ignition is switched on. Any help would be appreciated.
I'm looking for the ignition live to. I got yo test these middles ones when I get a chance.
Please let me know if you have any luck
As Pauly said, all of the centre column ringed in blue (and the one above) are ignition live. I'd avoid piggybacking the airbag one.
I used the 15amp fuse which is 2nd down (the top one being a 5amp). This 15amp is the washers & wipers fuse.
So far so good it's working OK.
