Perfect!!
No I should get mine around the end of April all things being equal, and who knows with the way things are.Perfect!!
Thank you; did you. get your van yet?
Fingers CrossedNo I should get mine around the end of April all things being equal, and who knows with the way things are.
... so how much extra ground clearance did you achieve ?.. going by your top pic it looks considerable, unless your jack still has the weight !I’ve run 225 65 R17 KO2 and currently running 245 65 R17 KO2.
They both fit without modification on standard suspension on the 4Motion California without the table in the sliding door rubbing. There is very little mud clearance between the outer diameter of the tyre and the rear of the rear wheel arch though. I really need a lift. View attachment 94604View attachment 94605View attachment 94606
The Jack still has the weight. I would be very happy with a suspension lift like that.... so how much extra ground clearance did you achieve ?.. going by your top pic it looks considerable, unless your jack still has the weight !
Great look too
.... if you still have them, and if you get time, could you please measure your old wheel plus tyre and compare it to your new wheel plus tyre measurement. That will give an indication on standard suspension how much extra ground clearence you’ve achieved .... Cheers LeeThe Jack still has the weight. I would be very happy with a suspension lift like that.
Sorry I don’t have any measurements for you. I’m still on standard suspension. So the only additional ground clearance is in the sidewall of the tyres. It’s pretty small but does just take my California over 2m in height which apparently is an issue for some car parks. Not that I’ve found any yet.
Lifted suspension is my next mod. I’m undecided between static and air.
`or you could type the size into will they fit and that will tell you exactly the extra.... if you still have them, and if you get time, could you please measure your old wheel plus tyre and compare it to your new wheel plus tyre measurement. That will give an indication on standard suspension how much extra ground clearence you’ve achieved .... Cheers Lee
