Van due an oil change service… is this basically exactly that and nothing else? It’s still under warranty so not sure whether to go main dealer or Indy? My local vw is a Johnson’s but not sure if they do vans yet. Any other recommendations around this way?
T6 Service intervals & inspections , Flexible & Longlife :
Im just posting this here to make it easier to refer back to in future . . .
source: Volkswagen Flexible Service Regimes (Longlife) | Volkswagen
As a Volkswagen owner, you will already have experienced the pleasure of driving a car that's renowned for reliability. So when it comes to servicing it, why settle for second best? Visit your local Volkswagen Retailer or authorised repairer who will be ready to help you every step of the way. Their staff are fully trained in every aspect of servicing to ensure you continue to enjoy mile after mile of trouble-free driving.
You can choose from two types of service regimes, depending on your driving methods.
Fixed Service (Time and Distance)
We recommend this service if you are likely to drive less than 10,000* miles in a year, and if you tend to drive in the following way:
  • Mainly city centre driving, short journeys with frequent cold starts
  • High engine loading activities, e.g. frequent hill climbs, driving with your vehicle fully loaded and towing
  • Uneconomical driving using high rpms with heavy acceleration and heavy braking.
Flexible Service Regime (LongLife Service)
We recommend this service if you are likely to drive more than 25 miles a day, and if you tend to drive in the following way:
  • Regular long distance driving
  • Driving at a constant speed with minimum vehicle and engine loading, and minimal towing
  • Economical driving
This Flexible regime has been made possible due to the development of new Volkswagen engines with the latest technically advanced longlife oil. These engines use built-in sensors that continually monitor the oil quality, making it possible to enjoy reliable and confident motoring for up to a maximum of 18,000* miles or 24 months (whichever occurs first).
*Please note that all mileages are approximate as the service indicator system uses kilometres as the distance measurement.
Big, Small, Big, Small, Big, Small . . . . and so-on.
Source: Service Plan Options | VWCV - link removed by VW
new source (pay on demand): VW Commercial Vehicles Service Options | VW Vans
Transporter T6 :
Interim service - £145+vat (oil/filter/Health check)
Interim service
We'll make sure to check the:
  • Wipers, washers and fluid level
  • Horn
  • Lights
  • Condition of the front and rear lamps
  • Instruments
  • Battery 'magic eye'
  • Coolant level and anti-freeze strength
  • Condition of visible drive belts
  • Brake fluid level
  • Power-assisted steering wheel
  • Saturation indicator on the air filter (if fitted)
  • Tyre condition, wear patterns and tread depths
  • Tyre pressures and correct them if necessary
  • Brake system for leaks and damage
  • Thickness of the front and rear brake pads/linings
  • Steering and suspension for wear and leaks
  • Drive shafts
  • Condition of the exhaust system
  • Change the engine oil and filter
  • Reset the service interval delay
Full service - £295+vat (oil/filter/Health check/as per service schedule)
Full Service
  • Lights
  • Horn
  • Instruments
  • Washers and wipers and top-up fluid
  • Tyre condition and tread depths
  • Tyre pressures and correct them if needed
  • Airbags for visible damage
  • Sunroof
  • Tipper system and change the oil if necessary
  • Paint and bodywork for damage and corrosion
  • Expiry date on breakdown set
  • Engine and engine compartment for leaks
  • Gearbox, final drive and rear axle for leaks and damage
  • Manual gearbox oil level
  • Final drive oil level
  • ABS sensor and cables
  • Underbody sealant and panels for damage
  • Supplementary rubber rings
  • Steering joints and boot for wear and damage
  • Coolant levels and anti-freeze strength
  • Condition of the camshaft drive toothed belt
  • Power-assisted steering oil level
  • Brake fluid level and condition
  • ATF level (automatic)
  • Battery
  • Idle speed
  • Adjustment of headlights
  • Drive shaft
And we'll also:
  • Run a vehicle systems test and read fault memories
  • Grease the front door check-strap and hinges
  • Grease the trailer coupling
  • Change the gearbox oil if necessary
  • Change rear axle oil if necessary
  • Renew the air filter
  • Renew the pollen filter
  • Renew the fuel filter
  • Perform engine basic settings
  • Perform a road test
Most vans are set to Long-Life 18000mls/24mnths by the dealer.... But I've noticed if you play with the MFD it defaults back to 12000mls/12mnths (which I've done twice now....oops!)
  • You can choose from two types of service regimes at VW Van Centre (Hatfield), depending on your driving methods. Your VW van also has the benefit of a service indicator on the dashboard to remind you of when a service is due.
  • Service Regime One: Fixed Service (Time and Distance) – the first of 12,000 miles or 12 months
    • Recommended if you drive less than 10,000 miles a year
    • You drive your van mainly in town centres / heavy traffic
    • You make frequent short journeys
    • You often use your van for towing or heavily laden
    • Your driving style involves hard acceleration and braking
  • Service Regime Two: Flexible Service (Long Life Service) – the first of 18,000 miles or 24 months
    • Recommended if you drive over 25 miles a day
    • You often use your van for long distance journeys
    • You rarely tow with your van or use it to its maximum load capacity
    • You adopt an economical driving style with minimal engine loading
VOLKSWAGEN VEHICLE HEALTH CHECK:
34 POINT VISUAL CHECK OF ALL THE WEAR AND TEAR ITEMS ONYOUR CAR
Vehicle Health Checks | Across the UK | Lancaster Volkswagen
Main exclusions
All non-standard service work:
  • Glass, including windscreen glass and head lamp lenses
  • Tyre replacement or puncture repair
  • Wheel alignment
  • Oil, air and fluid top-ups between services
  • Maintenance and repair of non-factory or non-standard fitted items/accessories
  • Broken aerials
  • Fuel
  • MOT (apart from the Buy 4 package)
  • Roadside Assistance
  • Camshaft belts/chains
  • Drive belts/chains
  • Body repairs
  • Any repairs or maintenance associated with the diesel particulate filter
Damage caused by:
  • Negligence, abuse or misuse and accidents
  • Food, drink and cigarettes
  • Any form of corrosion including pollution, water, chemicals
  • Salt and weather
  • Using the incorrect oil or fuel
Service and maintenance plan
  • Any repairs not deemed reasonable fair wear and tear
  • In-car entertainment (inc. audio, communications and navigation systems)
  • Internal and external trim and bodywork
  • Any maintenance or repairs to diesel particulate filters and any other form of catalytic reduction system
  • Warranty work
  • Oil and fluid top-ups between services
Service, maintenance and tyres plan
  • Misuse or vandalism
  • Wheel alignment as a result of damage or negligence
  • Accidental damage and irreparable punctures
  • Replacement of non-standard tyres and upgrades
  • Tyre sealant, repair equipment and tyres that have been repaired using sealant or additives
Thanks that's useful.. however I'm still not sure what service its asking for.. is "Oil change service" the same as interim?
Can anyone recommend a specialist in the midlands area, dealers are quoting £811 for cambelt & waterpump.. (4yr old T6 with 40k miles). Don't mind travelling abit for good service. Have used Listers in Coventry and Parkway in Kettering before but not been overly happy with the service for the prices charged.
I've had consistently good service from Sunset VW in Derby who are an independent VW group specialist.
Hi - Just moved into the Stafford area. Can anyone recommend garages for T6 servicing in the area.
Had issues with the “stealers” up in Stoke previously when we bought the T6, so don’t fancy using them.
Thanks.
Mine goes to midland VW from Tamworth. I've used them the last 10 years for all my vag stuff. They are doing a few transporters now. They really know there stuff
Hi all, hope you’re well!
I’m being stunned by the cost of main dealer services and maintenance and as my van’s a couple of years out of warranty am considering going for an independent alternative.
Are there any trusted indies in the West Mids please, Dudley/Wolverhampton area preferred?
Cheers!
Patrick.
I can thoroughly recommend @Deaky 's recommendation, I would never go anywhere else! Parking can be a bit tight, but they won't, certainly won't, rip you off. Nice little cafe a minutes walk away while you wait.
Cheers!
Patrick.
Another for midland vw they have just bought a unit in leamore walsall so they’ll be opening up there too soon .
