Induction-only cooking setup
shunt is directly next to the battery and was originally set up with help of loz amd Dell, so pretty confident the shunt readings are all good
Great. Process of elimination.
What doesn’t make sense here is that the % remaining on the battery as reported by the shunt doesn’t match the observed current (which is exactly what you’re saying). Could it be something to do with the voltage being variable over the discharge while boiling or as the battery gets further depleted? Might that explain your observation that it draws more as your stay gets longer?
Thats what doesn't make sense to me either, but i have no way to double check what the Ah is in the battery other than what the shunt tells me.
This is the phenomenon I’m referring to, put far better by this chap:
Probably:-
As you draw current the battery voltage will drop. More so as you draw at or above the rated discharge current. As the voltage drops the inverter will compensate by drawing more current to maintain its own power output. (ohms law)
The Ah capacity of the battery is regardless of the voltage.
In my case, I have a 180amp Lithium LifePo4 and a 1800watt inverter fitted. We use an portable induction hob all the time whilst away, and it works a treat. Evening meals take about 20/40 minutes and whilst the hob can draw in full power a lot of amps, we never use it on more than setting 3 ( Boil water around 170/180amps ) and on settings 1 30/40 amps. To date, we have never seen the battery go below 40% after cooking a meal. If battery in 100% full, it drops to around 75%/60% Then we plug in coffee maker and it takes another 10% for 2/3 coffees. The next day (here in Spain) depending on time of year it's full again by 4pm or we drive to new location and B2B does the job.
We have not used the gas cooker for months now (it is ready just in case). We also have my old Army jet boil (10 years old now) but find induction does it quicker.
Next time we are out in the camper, I will do some tests and take photo's
electric kettle v Hob
ok test done.
1Lwater in electric kettle took 4minutes 15 sec to boil, it drew 171amps continuously.
the ‘battery computer ‘showed it used 19amp/ hr from battery.
1L water in hob kettle, I switched it on and adjusted the power such that it also drew a peak of 171 amps (showed 1800W setting) . It took 8 min. 15 sec , and showed in total 25amps/hr taken.
clearly the power used dropped away as the hob cycled on and off.
also noted the interior LED lights flicker when induction running.
I have now ordered a suitable size electric kettle and sent the hob kettle back from whence it came.
For an electric or diesel hob you really must have a kettle with a thick stainless steel base that’s perfectly flat to get conduction.
The cheaper kettles that are OK with a gas hob just don’t work well at all.
Maybe not quicker but return on investment is a couple of days instead of years.
i think when you have seen 50k plus disapear down a VW transporter hole a few hundred quid investment in an induction hob it peanuts ;-)
What size solar panel you got?
I think the lithium bank is the real cost. I get by with 110Ah of AGM with no issues.
I agree with @DXX on the virtues of the Wallas duo.
I have one and it's awesome, but also have a small electric kettle for the quick brew. Kettle was £20 and the Wallas was compatible money to a diesel heater and hob.
Nominal electrical draw, limited condensation from no naked flame, no need to store a gas bottle, safety from no gas, all add up to the Wallas and small electric kettle being a great option.
(I have a single induction hob that I carry on my caravan; to save gas on our travels, but concern over battery capacity rules out induction cooking for me unless on EHU.)
I have 200 watts panel on the roof and 100 watt portable. On a good day here in Spain I can get 10/15amps in spring/summer/autumn 8am to 9pm, in winter 6/10amps 10am to 4pm
I timed how long it takes 1 pint of cold water put in a cold kettle to boil on my Wallas. Going from heating mode (min thermostat setting) to boil was 2 min’s 10 sec’s.
