Did you put them back in the same cyls, as they are coded?Hello Gents
Torque setting is 8NM, next to nothing and then 270 degs (3/4 of a turn). Have done this, engine is a runner but still not as smooth as it should be so ongoing.
Cheers Baz
Did you ever get this resolved Rory? Decently replaced my rocker cover gasket, injector rocker seals and all injector seals all genuine parts fired it up and low an behold between 1200rpm/ 1400rpm it has a very apparent misfire, I did get a code; P100600 Torque Difference Cylinder 3 Limit Value Exceeded so ordered up a new delphi injector as the values was out of wack. Cylinder 1 & 2 values are -28 -40 where as cylinders 3 & 4 Values where 34 & 42 but figures where fluctuating massively.
Let me know how you get on i recently had the code p100500 for cylinder 2. Changed injector and still came up with same issue has very rough misfire under acceleration especially cold and blows a cloud of white smoke calms down once it’s warmed up to temperature but still has a knock slightly on acceleration so misfire still there.Did you ever get this resolved Rory? Decently replaced my rocker cover gasket, injector rocker seals and all injector seals all genuine parts fired it up and low an behold between 1200rpm/ 1400rpm it has a very apparent misfire, I did get a code; P100600 Torque Difference Cylinder 3 Limit Value Exceeded so ordered up a new delphi injector as the values was out of wack. Cylinder 1 & 2 values are -28 -40 where as cylinders 3 & 4 Values where 34 & 42 but figures where fluctuating massively.
Had horrendous injector knock under acceleration coupled with the rough running and been down on power.
Going to try some G001790M3 diesel fuel treatment then go from there.
Just thought I would ask the question to see if you got to the bottom of it
Sometimes if it ain't broken don't fix it I read this post before I started and nearly didn't do the job wish I bloody hadn't now!
Hello there, I got rid of the code on cylinder 3 however still hear diesel knock and have a very misfirery engine between 1200-1400rpm regardless of it being cold or up to temp also more so in 3rd gear and above you can really feel the engine pegged back on performance so just nursing it currently.Let me know how you get on i recently had the code p100500 for cylinder 2. Changed injector and still came up with same issue has very rough misfire under acceleration especially cold and blows a cloud of white smoke calms down once it’s warmed up to temperature but still has a knock slightly on acceleration so misfire still there.
I will be carrying out compression test this weekend to see how we get on. Will keep you updated
Just to add also, I was watching a darkside developments video on the T6 platform the other night and they have had brand new Delphi injectors Dead out the box so just bear that in mind toLet me know how you get on i recently had the code p100500 for cylinder 2. Changed injector and still came up with same issue has very rough misfire under acceleration especially cold and blows a cloud of white smoke calms down once it’s warmed up to temperature but still has a knock slightly on acceleration so misfire still there.
I have bought the same stuff I believe VW Diesel Additive but I put in injector cleaner from another brand beforehand it didn’t do the trick hence why I purchased a new injector. My friend recommended me to swap the injectors around before digging too deep in opening up the engine. As like you mentioned about dark side development injector may even be the issue. The code you had was it as simple as clearing the code off or did you have any work carried out?Hello there, I got rid of the code on cylinder 3 however still hear diesel knock and have a very misfirery engine between 1200-1400rpm regardless of it being cold or up to temp also more so in 3rd gear and above you can really feel the engine pegged back on performance so just nursing it currently.
I've ordered a full set of Delphi injectors as no one was getting back to me on injector deviations/ cylinder torque etc not cheap however you should never disturb a happy fuel system so I was told I wish I had just left the oil leak
It's got the VAG Fuel Treatment in there to as it was a pittance and thought I'd try my luck knowing it wouldn't make matters any worse
I hope you get to the bottom of yours but keep me posted
