Got them on ebay
Got them on ebay
Hi allThreads merged
Hi all
Does anyone know if there is a female for this connector. Stupidly when I had my pop top added, I didn’t ask for the courtesy lights pop outs but just the cable. Having changed my mind the connection is in the wrong place at the rear and I can’t get it pulled to the pop out. I was thinking of adding a female then running new cables to the pop out. The other option I suppose is to cut the connection off and rewire.
Euge, where did you get the socket from, were you able to sort the pins? Trying to do the same !!Well I got the female socket, it has no pins at all. How do I make up the connection?
Male plug is different on a 6.1I’m a T6. If you have the same male end then it doesn’t matter, it’s about the plug and socket.
Hi Euge,Yes I got it sorted, added the pins and wires it all up.
The male socket was from EBay and came as a pack of two. Search - Fit For Transporter T5 T6 Crafter Interior Reading Courtesy Map Light Wire 2pc. That’s how it was listed.
I needed to extend the cables so I cut off the socket and re wired new ones. I suppose I could have re used the ones I cut off.
The female socket was a Vw part I looked up the part number from wiring diagram and Google searched it. The part is vw part 535972713.
The pins were also from EBay. You crimp the wire in and slide them in. 1/1.5/1.8/2.2/2.8/3.5mm Male Female Car Crimping Terminal Pin Fits VW Tyco AMP
I used flat 1.5
Hope that helps
Eugene
