Is lining a van really a DIY job?
ok you ll see when you poke the drains though compare prices before going to Kiravans THQ MVM and a lot of trade sell it all now
would go as thick as you can on the roof to keep it cool inside.. would still recommend DODO the foil is bonded onto the foam you only fit this stuff once it blocks sound out from outside too and your snoring inside lol
After a bit of research, went for the dodo pro stuff (10mm foil backed foam). Wow, what a difference. Not really comparable to the other stuff I'd bought.
Dodo stuf is far more comliant so doesn't attempt to unpeel itself when stuck round a curve. The foil is properly bonded on one side and the adhesive properly bonded on the other. I've stuck it to the roof and it has stayed put for several days now. No hint of peeling/separatng.
Wish I'd used it on the sides and in the sliding doors but I'm not about to start over from scratch. Most of that stuff is held in place by the polyester fill and door cards so hopefully it'll be okay anyway.
Anyway, other products ara available but thumbs up for the Dodo stuff from me.
