So, relatively new, good quality battery. Been doing a few shorter journeys. Battery light came on while driving a few times and when i went to put Carista on after a day or two it would not start as it said the battery was too low. I charged the battery up plugged in and there was a fault code.
02252 Generator, no signal communication.
The engine is also revving slightly higher than usual at idle (1000 vs 900 ish) and fuel economy is a little better??
I fully charged the battery last night and then drove to swimming 25min A road and duel and coming back the battery light was on again.
Caravelle t6 euro 6 150 manual
Could this just be a corroded wire under the engine or has the part failed?
Many thanks
Toby
Many thanks
Toby
