Is there an easy way to drain the Adblue tank?
Howzat
T6 Legend
So I'm at the 250 mile warning. Was hoping the adblue issue would rectify itself but it 'aint happening so I'm gonna have to drop some out of the tank to see if that resets it.
I see @lucky13 managed to do this by getting underneath and removing a pipe with a quick release connector to drain it which is my plan but just wondering of anyone managed to do it an easier way?
The Amorak has a drain plug at the bottom of the tank but I don't think the T6 does. Using a syphon doesn't appear to be a solution because you can't get the pipe to the bottom of the tank via the filler neck.
Anyone?
When I dropped the fuel tank I also used the quick release connector to remove the Adblue fill pipe. I’m fairly certain there is no drain plug.
