It started with the wrong gear being displayed, now CC is inoperative as well as ...
ScreeminWheels
So a week or so back I noticed my T6 Gear display showing 6 when I was in 5. Then a couple of days ago I got a warning on the MFD the Cruise Control with an exclamation mark. From then on wards I had no Multi Function Steering wheels controls work, the horn didn't work and electric windows wouldn't operate. Now I'm no slouch when it comes to servicing, brake pad/disc changes or audio installation but this has me stumped. Any ideas folks? Here's the most recent Vagcom scan...
Wednesday,11,December,2024,16:29:28:27650
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240919 DS356.3
www.Ross-Tech.com
VIN: WV1ZZZ7HZGH145319 License Plate: R321MKY
Mileage: 96480mi Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 5F 61 0B
VIN: WV1ZZZ7HZGH145319 Mileage: 155270km-96480miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
5F-Information Electr. -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: OK 0000
Address 01: Engine (J623-CAAC) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 GQ HW: 03L 907 309 L
Component: R4 2,0L EDC H38 8440
Revision: 22H38--- Serial number: 00000000000000 CVN: B896F1BA
Coding: 01194012232401080000
Shop #: WSC 65535 000 00000
ASAM Dataset: EV_ECM20TDI01103L906019GQ 003006
ROD: EV_ECM20TDI01103L906019FH_003.rod
VCID: 005989BD5A85C32A5FB-8054
VINID: 9E606AAAA1D8A976011050C12440CF666B
1 Fault Found:
4483 - Function Restriction due to Faults in Other Modules
U1113 00 [00100111] - -
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 155275 km
Date: 2024.12.11.
Time: 16:27:08
Engine RPM: 858.50 /min
Normed load value: 28.2 %
Vehicle speed: 0 km/h
Coolant temperature: 60 C
Intake air temperature: 24 C
Ambient air pressure: 1030 mbar
Voltage terminal 30: 14.740 V
Unlearning counter according OBD: 40
Cruise Control System (CCS): switch position-Bits 0-7: 66
Cruise Control System (CCS): status-Bits 0-7: 204
Cruise control switch-off: irreversible-Bits 0-7: 0
Cruise control switch-off: reversible-Bits 0-7: 255
Cruise Control System: specified speed: 0.00 km/h
Engine control module reset status-Bits 0-7: 0
Engine control module reset status-Bits 0-7: 2
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 1
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H05 0132
Revision: 00000000 Serial number: 41256000000305
Coding: 307E4098256684830C780277A48B21D3390000
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FDB4A4167FB7CD2661-806A
No fault code found.
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 06051613470348
Coding: 01
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5F7452071B5DA2D7-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 AJ HW: 7E0 907 047 AJ
Component: Climatic-T5 H22 0708
Revision: 00001002
Coding: 0000000003
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis_VN75.rod
VCID: 72BDD3756429E1BA59F-8026
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0736
Revision: B9080001 Serial number: 0771 127160960
Coding: E0F479B80A61341193284F746CEB9EFD0F80710F60CD6D60320400230800
Shop #: WSC 02737 022 169722
VCID: 6889B11D52751B6AF7B-803C
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 080516 03 37 0059
Coding: 0228EE
Subsystem 2 - Part No: 7E1 951 172
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 3 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
Subsystem 4 - Part No: 7E1 951 172
Coding: 000000
1 Fault Found:
03020 - Local databus 2
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 23
Mileage: 155275 km
Time Indication: 0
Date: 2019.05.04.
Time: 16:27:06
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 R HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0210
Revision: -------- Serial number: 32961609001761
Coding: 108008
ASAM Dataset: EV_VW75XParkAssis4K 001012
ROD: EV_VW75XParkAssis4K_001_VN75.rod
VCID: 41DF4CB9110F0A22105-8014
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 G HW: 7E0 959 655 G
Component: VW10Airbag01N H08 0018
Revision: -------- Serial number: 003V3000SEKD Dataset Number: 7E0003V____ 0843
Coding: 00000000000000000000000000000000314E
Shop #: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3A2D3B557CD959FA51F-806E
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 970 L HW: 7E0 920 970 L
Component: KOMBI H05 1008
Coding: 440B010100
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05730
ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
VCID: 333316715BB3A8B2929-8066
2 Faults Found:
10486016 - Control module
B2001 00 [00001001] - Incorrect software version
[BAP: Steuerger t falsche Softwareversion]
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 23
Mileage: 155275 km
Date: 2024.12.11.
Time: 16:27:06
13654544 - Databus
U1121 00 [00001001] - Missing Message
[Steuerger t f r Telefon keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 23
Mileage: 155275 km
Date: 2024.12.11.
Time: 16:27:06
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H80 0736
Revision: B9080001
Coding: 042305
1 Fault Found:
03158 - Control Module for Information Electronics 1 (J794)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 23
Mileage: 155275 km
Time Indication: 0
Date: 2019.05.04.
Time: 16:27:11
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 1008
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW23.rod
VCID: 6A8DCB154CF9297AE1F-803E
Address 5F: Information Electr.
Cannot be reached
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H80 0736
Coding: 030B1A73
Shop #: WSC 02739 790 12345
Subsystem 1 - Part No SW: 7E0 915 181 G HW: 7E0 915 181 G
Component: J367-BDM H08 0223
Serial number: 63116C39361261967621
End----------(Elapsed Time: 01:31, VBatt start/end: 14.9V/14.9V)-----------
