Jet Washer Spray Nozzles
@Pauly I want to change my washer jet nozzles that currently spray 3 jets of water, to the fine mist type of spray. I would assume mine are heated on a 2018 Highline Kombi. What part number do I need to order and where from? Thanks mate
They are only heated if you have LED headlights
Send me a pm and I can either post you a set or provide part numbers
can someone tell me how to get the bonnet liner off (funny little square plates/clips that I don't want to break) and how do I access the washer bottle and it's pipes please? When I pull for a wash motor is good, offside nozzle functioning but nearside nothing and water streaming out below....from where I know not, please help me? Obi one, you're my only hope....
You don’t need to remove anything just lift the bonnet and pull the washer/nozzle piece out of the bonnet, it comes out quite easily and you will prob find one of the pipes isn’t connected properly
Probably as Pauly says, give that a check first.
Just because you asked though, the square clips release by squeezing them together on the edges parallel to the slot/overlap in the centre. This is what they look like off the vehicle:
Fabulous, thank you so much, it's the little things.... :inlove:
You are an absolute superstar...and completely correct, I popped the nozzle housing out and the pipe just wasn't clipped onto the "nipple" :oops: now it is and its all working brill with no leaks....thank you, thank you, thank you :inlove:
So I've not got heated washer jets, which part number do I need to order and how much am I looking to pay?
Standard T6 heated ones are 7E0955987A & 7E0955988A (they are handed)
or the spray nozzle type i tried out are 5M0955986C 9B9 (these are not intended for T6 and seem to shoot a little high but are ok when driving)
I should point out as per the other thread Heated washer jets
i have one set left of standard T6 ones on the shelf with the wiring made up ready to go for £95
I ment to update this a while ago when I modified my mod!
In order to gain a bit more adjustment I reprofiled the adjuster screw stop so it wouldn't clash with the inside of the washer housing. This allows more adjustment/ travel before it comes to a stop.
Modified on the left, unmodified on the right:
Standard adjuster profile:
Modified adjuster profile - now more of an arrowhead:
The reason for the reprofiling of the adjuster screw stop:
Both jets modified:20210620_163810.jpg
Both jets modified:View attachment 142213
Does it hit the windscreen in the right place after modifying it?
IMO it depends if you are moving or not, the mist jets are much more susceptible to wind/air movement so hitting the middle of the screen when stationary means its hits quite low when driving and vice versa
Persoanlly i set them high aiming for top of screen as when you are in motion (when i use them most) then hit the right spot
Resurrecting an old thread here but I found it very useful when my standard heated jets stoped working!
Swapped them out with the ones linked below.
Different part number and I’m not normal keen on Amazon for car parts, but for the price I thought it was worth a punt.
They have a different part number but fit perfectly and are currently working very well (as others have said they spray quite high even on the lowest setting but nothing major and it’s the perfect height once moving)
Listed OEM part number: 5M0955986C
Link: Amazon.co.uk
Thanks for the link, I also order some and they arrived today.
Can anyone confirm the wiring harness connector? I think it 8E0973202
