I would like to know if you can set the mirrors to fold on locking![]()
Leighton vans were unable to do this with my t6.1 with VCDS because my van is too new. Interested to see if it could be done with Carista
If you have H4 lights, the ones with the 1 candle output, the bulbs may not be able to take that mod. It's a H7 thing..Does Carista let you change your full beams so that when on normally your main beams stay on as well, rather than switch to fulls instead? I have that when I flash my lights, but not when I put them on normal full beam
Not sure if I need VCDS for that instead
Also, one more question. Once the subscription runs out does it work just like an OBD reader? Can you reset fault codes with it?
Maybe the aftermarket alarm popular in the 80s/90s that used to bleat "System armed" like Kitt while you swaggered over to your mates?!!!The loud clunk of the door locks and the flashing indicators not enough for you Pukkster?
which one do you recommend...............I've been holding off on getting oneCarista Beta let's you do that mod I believe!
And no I don't believe it'll let you reset without paying the monthly fee...
Personally I've upgraded to Obd11 now, I wish I had gone straight for that at the start, not much more money in the first place and it works without a subscription up to a certain point plus the subscription is cheaper![]()
Thanks, this is a helpful responseCarista Beta let's you do that mod I believe!
Buy the first gen one, 50 quid on amazonwhich one do you recommend...............I've been holding off on getting one
