Has anyone added a mod such as a cowl etc to help keep the lens clean.
Hmmm... you could probably could not see anything either.....
The A6 Avant has a tiny washer jet built into the camera which works when operating the rear wiper
The A6 Avant has a tiny washer jet built into the camera which works when operating the rear wiper, could be worth looking into? Just uses a T off the washer pipe. Not looked into it so no idea if it uses the same size housing for mounting into the tailgate. It does clear off rain water, tried one yesterday while driving it in heavy rain.
Don’t you find it confusing with the image flipped rather than mirrored, or is that just the way the photo has posted?This is my BlackVue set up in mirror mode on an old iPhone. Black and white image as it is an IR camera mounted externally on the tailgate. It is on all the time as I have a solid bulkhead and tailgate. Works in real time with slight latency compared to the E-Tron wing mirrors.
The day this was taken, it was persistently raining so not too bad.
If you imagine a horizontal line across the bottom of the screen, a mirror will flip it around that axis. If you drew a vertical line down the centre of the screen then your image is flipped about that axis. In fact you can see in the photo that it shows you driving on the wrong side of the road when you're obviously not. Have a look at a speed limit on the road in a mirror and you'll see what I mean.No as it is exactly the same image you would see if you looked in your rear view mirror. Also it is a much clearer image than the factory camera. as it is hd but not in colour.
It could be that the photo has been flipped posting, but for example if it was in a normal mirror, the 4 and the 0 would be the other way round even if you were on the wrong side of the road.I have the same set up in my car and when I look in my rear view mirror, I see the same on the phone screen in the car so must be something to do with the photo. Unless my rear view mirror is playing tricks on my eyes?
Do you mean me? I'm not a detractor, I have used permanent rear cameras myself in the past. If you read what I put, I was just pointing out the image was reversed, it's sort of my fieldRegarding the rear view image and comments concerning accurate representation of image. No or very few mirrors give an undistorted 1:1 most give a diminished image of some degree or other. I would hardly expect any camera to match exactly either a rear vie mirror or a side view mirror so I am not quite sure what the detractors are on about.
