My factory fitted third row bench does not have the extra brackets.
I think I read your comment in another thread and that got me thinking. I understand brackets in the second row but adding them in the third two seems less common and potentially unnecessary.My factory fitted third row bench does not have the extra brackets.
Why, if the factory don’t fit them?The rear triple has reinforcement brackets, same as row two. All are available from VW. There is plenty of space for them and bolts are long enough.
It’s the factory rear single in a Shuttle on the n/s that doesn’t have any brackets form factory - we still fitted brackets when retrofitting this position.
Are you talking SWB or LWB. Mine is a SWB with a bench originally in R3. As you say its odd the 2nd row with a 2 and 1 seat (8 floor brackets) gets reinforced yet the 3 seat bench (4 floor brackets) gets none.Because we like to be double safe - Its odd how they have reinforcement plates on all seats bar the outer single, third row - I have to say we were shocked when we saw it. We are happier putting the plates in - There is plenty of thread length and room for them![]()
Is it possible to move the 2nd row 2+1 seats backwards to a third row position in lwb kombi?The rear triple has reinforcement brackets, same as row two. All are available from VW. There is plenty of space for them and bolts are long enough.
The wheel arches get in the way of the feet - The triple is designed for the third rowIs it possible to move the 2nd row 2+1 seats backwards to a third row position in lwb kombi?
This thread may help:Dose any one no what reinforcement brackets I need to fit a single seat on 3rd row center of panel van thanks kirk
@foggy3061 great guide, I'll start my seat fitting and use it as a reference. Although I will just install the single seat that is closer to the door only.
Does anyone knows if I need to use the 7H0802763A (long reinforcement) even if I will fit the single seat or if it can be replaced by 7H0803547A (short reinforcement) & 7H0803548A ?
Also, the diagram show the use of another reinforcement: 7H0802369. Anyone knows what is it used for?
Thanks!
Just to double check before I order from TPS, i'm fitting a 2+1 Kombi Seat setup in my Panel Van. Am I right in thinking I need the following Reinforcing Brackets....
7H0 803 547A - 4no
7H0 803 548A - 4no
7H0 802 763A - 4no
Thank you!
We’ve just done this and some fixings are tight and into box sections, so its tricky get the nuts in but once tightened the panel they sit on are already massively strengthened so you don’t need additional plates. I wish I had a car lift as it would be so much easier to take photos and a video! The pictures I’ve taken are really hard to see what’s going onI didn’t get those on my SWB 9 seat window van, just the 4 in the middle in R3. When underneath I seem to recall some of the fixings are inside box sections so not possible to get the plates on.
This is exactly what we have just done. The plates are simply to strengthen the metal to stop the bolt ripping through in case of an accident. The metal is so thick where you have taken pics this reinforcement plate isn’t necessary.Hi can any one give me advice on a 3rd row seat my van is lwb so drilled holes 4 r on cross member the other 4 r in side the rear trailing arms the metal looks to be 3l ayers thick in there do I need to try and get plates in there here’s the picture below of the holes inside trailing arm box section on the other cross member was advised to use the single brackets 7H0803547A so I have fitted them and riveted to the van just want to make sure it’s right with my kids in this seat any help would much appreciated thanks
