It’s just how they are set, it can be changed with VCDS etc but after the change you need to go into the menu and turn off ‘alt speed’ and that will let you turn on ‘digit speed’ in the mfd menu
It can be done using the Carista dongle if you have one. If not, they're pretty cheap on Amazon. Alternatively, I'm only an hour or so from you, so you could take a trip down here and I'll do it for you at the cave.
