Yes you can change the kph to mph. However you need VCDS/ Carista to do it, and it only displays it in the large format and not the little one as per current kph version.Is it possible to change the small kph on mfd to mph but keep it in the smaller size like the kph is currently? I’ve read that you can have it Larger but I like to look at my consumption as well.
Yes you do lose it, but it’s easy to switch back and forward from the MFD menu once set up ie you can put the km/h back for 2 weeks and then switch back on return without needing Carista or VCDS again. You can’t have the km/h large unfortunatelyIf this is done in Carista, do you loose the small kph display when the large mph is enabled? We rely on the kph display when travelling in Europe.
Also, can a large kph be shown? And if so, can you toggle between the mph and kph easily?
Thanks!
Not near the van at the mo but yes you tick or untick a box that says something like "alternative speed display" to toggle between km/h and large mph displayThanks @andys. If I read this right, after changing with Carista, do you end up with an extra choice (large mph) in the MFD display options available from the steering wheel MFD menu buttons?
Must admit I've always found that a bit baffling given that they don't use MPH in AustraliaFound it, all done a bit disappointed you can’t get it into large KPH though but it will do.
I programmed this and now I don't have coming home lights on when locking and unlocking the van.
Agreed - that’s what my Highline does.I thought we decided that the lights only came on automatically when unlocking, on lock you have to flash the lights first?
