Lazer Light t6.1 fitting
Do I unplug from the rear of the passenger headlight and then use a multimeter on the exposed loom? I just need to find the active wire for full beam. (I’m a bit shit at electrics 😂)
But there is another pin that is 3.8v and then 12v when full bean is engaged.
So now I’m not too sure?
What a nightmare.
I fitted the THQ lights which went in fine and look amazing!!
Then started the Lazer lamps, but the inner and out grill as per instructions but for whatever reason, the lamp brackets do not clip into the grill. The little hooks on the brackets that clip behind the grill don’t fit my grill.
It’s a VanStyle grill. Not sure if they are slightly different OEM.?
So I’ve got a nice hole in the grill and lights that don’t fit.
I’m going to buy a replacement grill and forget about the lazer lamps.
8b282bfc-8c49-4889-a34a-3afbd5093b77.jpeg38c28e08-2e92-4a40-8f31-18907e7f58f7.jpeg209d40d4-83a4-46fc-a8bc-e1a92ad580b8.jpeg4afbf4e8-4417-46e1-8c3e-1eae64ae76e6.jpege1540d23-f472-4318-9453-766cc0e4f1fb.jpegb2c1883f-b40c-45b3-a75e-cd509923ca09.jpeg
What a nightmare.
View attachment 280780View attachment 280781View attachment 280782View attachment 280783View attachment 280784View attachment 280785
Oh man, I feel your pain. The replacement headlights look great though. I think if I was you I’d just replace the grill and forget about the lazer lights too.
Right then, I had one more go today and have just about resolved the brackets not fitting, I’ve filed them down so they fit flush and I’ll use screws to secure. So all good.
But where do you feed the wires from the lamps into the engine bay? The only place I can find it either side of the radiator, but not too sure if the wires should be that close to something that gets hot?
I found a tiny gap, nearside/top of the rad. It won't get hot enough to harm the very robust loom provided with the kit.
Ah good. Looking forward to seeing the finished job 👍
