LED cabin interior lights
Don't bother with LED, it only takes one of the little LEDs to start flickering and that is just plain annoying!
One of my Travelin-Lite LEDs flickers for a few seconds every now and then..
I've had the same issue but it only happens to my 2 sliding door step lights. Got on to them and they have changed their supplier and sent me out a new set. Not fitted em yet but cant fault travelin-lite's customer service.
Mine are from Travelin-Lite as well. Bought over a year ago, they didn't last very long before they were flickering, just yet another flaw to the T6.
T6 flaw or flaw with the LED?
They’re both flashing now.
I have to be careful where I park, now.. It’s an epileptics’ nightmare.
Fitted the new bulbs from travelinlite a few weeks ago and no issues with flickering now..
Does anyone know if the Osram C5W LED 41mm fit the interior rear roof lights (the ones where the cover is a rocker switch in the panel van) as the factory spec says 42/43mm
Hi guys. Just bought a 2016 t6 transporter shuttle and am looking to change the interior lights to less. Can anyone help me remove the ceiling cabin units as there's nothing on the net
@Brumston to remove the rear lights you'll need a couple of trim tools. There are 4 metal spring clips holding in the lights and vents. So you need to push the trim tool in to depress the clips. Be warned though they bend and snap easily and then the light doesnt sit quite right. Im yet to find the part number to replace just the tab...
These two photos might help locate where the spring tabs are in relation to the light. See the rectangular holes where the tabs locate. Once you’ve worked that out they are easy enough to remove with care. 5A6F7B7D-27F2-433E-BFB3-D2ABBFEBB9BA.jpegD00430C3-420F-42D5-A74F-5057CE05250B.jpeg
