For Sale LED Footwell Lighting kits
@saxoboy
Are the lights a direct swap for filament footwell lights?
I've swapped the bulbs in the ones in my Scirocco, but they don't dim and flicker with the engine running.
Totally vouch for @saxoboy footwell lights. Fitted mine today, well made and a doddle to fit :thumbsup:
Hi Guys,
I have finally got around to creating an LED Footwell Light Kit….it comes with intensive instructions and all the bits and pieces for you to connect it into your van….all you need are the tools to fit it…..brute will and a crimper!
View attachment 61626 View attachment 61627
I’m after £27 per kit which, as always includes postage. The LED Footlights work like the existing courtesy lights in your van i.e. they will turn on when a door is opened and fade off in a few seconds, they will not stay on when driving….they are not sold as ambient lighting.
I do do other kits, which are; (and they all come with everything to connect the lights to your van including T-Taps and cable ties)
  • Welcome/ Puddle Light Kit - £35 - Cast the VW emblem on the floor to create light before you enter the van when you open either the passenger or drivers door.
  • Glove Box Light & Switch Kit - £32 - a light for the glove box that turns on when you open the glove box....VW seemed to have forgotten to spend a few quid!
Thanks for looking ….Matt
Hi saxoboy I would like a set of each - footwell/puddle/glovebox if they are still available?
Also did someone mention there is a bulb upgrade/upgrade for the centre overhead lights console? Is this something you also supply saxoboy?
You'll need to send him a private message, as your post didn't tag him. He doesn't do the bulbs as far as I know
Matt, @saxoboy can you supply a replacement LED light for the lower glove box? Middle top as you open it.
The one in mine is garbage and that is being kind.
Hi @Texxaco if you mean the difference between these 2 pictures...I think I know what you need...an LED from the Glove Box Kits I sell....I will PM you a message
