As you have lowered the van may be worth recalibrating the level sensors
We do this when installing new headlights to setup the system and all you are basically doing is telling the van when it is flat/level, all you have to do is reset all adaptions followed by basic settings and if successful once complete the lights will dive down then level out (same as when you key on the ignition) and this is your base level setting, I always do this on an mot test bay which I know is flat and use the beam testers to tweak the headlights for optimum/correct output (which they always are out of the box anyway)
