WolfieRose
Hi, really needing some help with my new camper.
I recently bought a T6 all kitted out. Everything seemed to work ok to begin with in the first month. I took it away on a weekend trip and noticed the battery was not charged so I had to go to a site and hook up to get electricity.
After leaving the site I turned all power off at the control panel expecting the charge to stay but within a short period of time the battery had drained again. I took it to a garage, they checked the battery and said it was at 6% and i needed a new leisure battery. Which they replaced for me. I went away and tried charging the new battery to full capacity but it was not fully charging. I asked an auto electrician to check the new battery, he turned on the power at the control panel and the battery drained within about 20 minutes completely. I was told by the auto electrician that I needed to get a new split charge relay (I currently have a VSR) he recommended I upgrade to a DC to DC converter instead.
Has anyone else come across this before? I am worried that changing the split charge relay may not fix this issue with the battery drain, considering it went down so quickly on a new battery.
Any help or guidance appreciated, I can provide more info if needed.
Thanks in advance.
From the Transporter newbie - keen to learn
Thanks in advance.
