Leisure Battery Woes
The app will tell you the starter voltage and the charging voltage. If your charger is warm after 5 hours of not driving then it’s possible that your charger is not configured correctly and is not detecting engine shut down. If this is the case you might end up with a flat starter battery.
This is what you should see when the engine isn’t running
