Levelling ramps, easy to use with DSG?
Has anyone found a solution of storing them under the van?
(Un-lowered of course)
I looked into this. I have a spare wheel and a large FW tank ahead of that.
I have stock T32 running gear with 17” wheels on a SWB. I found one space on the offside just inside the cill but decided against storing the ramps there as it is midway between the wheelbase and probably runs the greatest risk of grounding going over a bump.
Yeah the middle of the wheelbase will probably the worst spot. I was hoping that someone might have Engineered a storage box for underneath. I even wondered whether they could double up as a sump guard. Probably not! I think @Skyliner33 Might have the best solution. I’m going to check it out later
If you have black ramps you could bolt one each side below the headlamps, it wouldn’t look much different from a 6.1.
The front is a definite no no. There is space at the back either side of spare wheel. It’s got the depth for 20cm chocks but only 55 cm length max. Creating a secure box/frame for them to fit in is above my paygrade though!
The Fiamma are OK for narrow breadth. But the wider the better, except for storing of course.
The best skid plates are cut down bread baskets, a) They're free, b) wider than factory made, c) being open weave, more grip.
It isn't the cheapest option out there, but after much hassle mucking about levelling a twin axle caravan, I went for a Lock N Level, which has been a Godsend during 10's of 1000's of miles of adventures with a caravan.
I know that a T6 is not a twin axle caravan, but I figured a pair of Fiamma Ramps and a single bag may just make life a little easier!
