Let us know how you get on! Are you fitting it with the VW OEM Roof Rails?I hope not, just bought one myself. Will fit it as soon as we get a dry day (in May probably!)
ThanksYes mate, will let you know
Thanks.....did you put anything between the rail and the roof gutter itself, to protect the paintwork, or just straight on?I am pretty certain we have that awning rail, and we definitely have Omtec roof rails - they fit together fine.
Pete
Thank youStraight on I think. I made sure there were no sharp edges on the rail which could damage the paint.
Pete
I have this rail fitted with OEM roof rails but i used some threaded bar and nuts instead of the original bolts so the original rubber washers could be used without big dollops of sealer everywhere as suggested on here to stop any water leaking in. To answer your original question,it does fit without any trimming of the feet/spacers,hope this helps
Thank youIt definitely fits.
I understand your concern from looking at it but the spacers have enough play in them to move towards the centre of the van allowing for the rail.
Just remember to seal the roof bars up with silicone to prevent leaks.
Hi @SENTINEL ,have you already fitted the roof rails or not? I ask because when i fitted my awning rail and roof bars at the same time,i re used the original rubber washers that were already under the roof bolts but used threaded bar and nuts instead of the original bolts. Apparently,the sponge washers that come with the rails are useless but the original rubber ones are decent. There is a thread on here decribing how to use threaded bar for fitting roof rails so that the original seal is maintained without having to put sealer in the threads. This is how i done mine and alls well up to now but obviously the sealer or no sealer is entirely up to you,hope this helps you
Thank youIts under roof rail leak free fixing @SENTINEL ,good luck
Thank youJust use plenty of sealant as well
Pete
