Part number 4 is a "Decoupling Element" Part No. 04L145633 (5 of required)
Earlier version..
So after the first two visits a third was required this time the cylinder head was replaced. Apparently it's a know issue and has been redesigned since mine was new 2016. This has resolved the problem once and for all. I suspect it was the issue all along, thankfully I had the extra two year VW warranty. They just trace the water and replace a piece at a time and then don't test again. Seems like a way to get more money but she is back to normal running.In another thread I posted that they replaced the EGR. Coolant came back on again this time the charge air cooler was replaced.
If you have oil in your header tank I can't see the relevance of changing your coolant radiator, however if you have a coolant leak as a separate problem, that may be necessary.Hi to all in this Thread
I have a T32 or T6 2016 kombe
At the moment it is in VW dealers in mijas spain under going repairs.
I had noticed oil drips under the van were ever I park up and was getting worried about it so i gave SAFA VW dealership a call and the van is there I have been told that there is oil in the header tank and been giving a list of thing needed for the repairs my spanish is not that good but with some help I think they are going to replace the coolant radiator oil filter housing and all part associated with it.
engine oil sump plug and washer and purge the coolant system
I can only ashume that the oil has got in though a bad seal on oil filter assembly.
has any one else had this problem in the past or similar.
any help would be very welcome
There are plenty of vans to choose from, why would you want to take the risk especially as you are assuming it’s caused by a defective cylinder head.I was considering buying a 204 2016 R6. I've noticed on the invoices with the vehicle it has a coolant leak, which I have confirmed with previous keeper who also said it was using oil. What is the cost of a replacement cylinder head?
Possibly / probably two separate issues, did he say how much oil it was using? Worst case scenario it needs a new engine.I was considering buying a 204 2016 R6. I've noticed on the invoices with the vehicle it has a coolant leak, which I have confirmed with previous keeper who also said it was using oil. What is the cost of a replacement cylinder head?
