I just got back from the dealer having driven a 150PS DSG and Manual 6.1 PV. Our other cars are Auto (one electric) so I thought it would be an easy decision. It really was not. The DSG was almost as good as expected but the Manual was way better than I expected.
The thing I found slightly disconcerting was the DSG at low cruising speed. Trying to maintain 30 or 40 seemed unusually hard. The briefest brush of the accelerator and you are speeding. I spent most of my time with my foot hovering above the accelerator with tickover enough to keep me going especially on any hint of a slight decline. When I hit an incline I would then need a healthy push of the pedal before backing off again or braking on the other side
With the manual I must have subconsciously keep it in a lower gear so there is more effect from engine braking when you back off. This same effect is also pretty pronounced in electric cars as the regen kicks in as you pull off the pedal giving you a one pedal driving experience for all but a few occasions where you need to break quickly. With DSG I was conscious of how often I was on the brakes. None of this effected me at higher speeds where you needed to be on the accelerator pedal all the time, as expected, to counter wind resistance and maintain speed.
Has anyone else experienced the same? Is there a trick? Can it be adjusted? Is this why some people want to fit flappy paddles?
