Lowering without the ride being too hard
Hi New to the VW transporter. I have just ordered a 6.1 TDI450 4 motion LWB in Australia.
I also want to lower it 40mm on 18" wheels. I think I will go for the Bilsteine B14 Comfort but I dont know what front struts
it has .(bolt on or clamp on) Can anyone help and do you think this combo will give a good ride and still be able to tow a trailer when needed?
Firstly is the Comfort kit available in Aus . If it isnt and you want to import one please check to make sure it will be accepted by the authorities and can be used with out getting import clearance , many countries in Europe dont allow things like this to be imported unless they have safety clearance done by the importer usually . The most common safety clearance in Europe is TUV , ( not recognised in UK but it is used by many European countries ) . I do get asked by many people to send kits overseas but i always check with the manufacturers before sending to make sure there are no shocks ( excuse the pun ) on arrival . there are plenty kits available in Aus that will be type approved and we can advise you what to look for , Also if there is a failure you deal with a local company and not have to stress to get parts from europe .
Probably the easiest way to see which kit it is is to look at the lower front shock mount , if the 2 bolts are on the wheel side its T32 and bolt on , if the 2 bolts are at the back of the shock its a T 30 or T 28 and its the clamp on type
Hi @Richard Etches, I totally agree with both @Jayjmac and @ChrisR.... you’ll need some upgraded shocks if you go with the lowering springs.... I’m on 40mm H&R springs with standard shocks at the minute and it’s not great! I’ve already been in touch with Steve @CRS Performance for the shock upgrade.... he’s the expert, but is waiting on supply of the shocks. :thumbsup:
Was the 40mm lowering springs with original shocks any worse than the standard springs and shocks please ?.
Sorry Toby I couldn’t tell you mate…. when I bought my van it had the lowering springs fitted. There was nothing wrong with the springs (H&R), they just didn’t pair up well with the standard shocks. :thumbsup:
