Hi All,
I have a very strange fault that has now happened twice in recent weeks, when driving along at circa 60 mph I have twice had the same sequence of events. It starts with ACC Deactivation then ESC Fault light then TPMS fault light. Van continues to drive normally for a few minutes then the D7 gear selection light in the middle cluster starts to flash and disappear while at the same time the gearbox engages false neutral for split seconds at a time causing the revs to rise.
If I pull over switch off and back on everything returns to normal, I am thinking that possible one sensor is causing a knock on effect of the rest possibly a wheel speed sensor?
I have a code reader coming at the weekend but thought i would post now if anyone else has the same.
Its a 204 BiTDI DSG Caravelle 2016 with 80k
