As it's a portable panel, just hold it closer to the sun, right?yep defo, as @TallPaul_S says.
connect it now. . . you should see something. even if its only 10W.
well maybe 1W lol . .
Gents I am doing nothing more today I am done it’s been horrible in n out the rain today , up n down in n out the pop top (too bloody small for me) and my head is fried. I fear the only thing I am doing now is opening up a bottle of Mcguigan black label red and quietly whine to myself.Yes definitely. If you can, plug it in now - you might only see 1v but that would be enough to confirm the MPPT is ok. Obviously the battery won't charge at that.
Ok I checked the Vic fuse all ok.fuse for the meter will be under the rear cover - normally a 10A glass tube type.
the Vic mppt doesn't normally need a reset, but if it does, remove the power battery + solar for 60secs.
have you got another power source? small battery? 12v battery?
any dc power (11-75v) can be used on the PV port of the MPPT, - to check if its working.
if you test the mobile van and get the VOC, then you should see the same voltage when the wire are screwed into the Vic, . .
unless the Vic is defective, - very unlikly.
but you should also be able to test the current from the panel with the meter in AMPS mode, so something not right here,
two possible issues,
id start by looking at your meter or get a second know good one.
new test meter? - same day delivery for £20 odd?
Yep, either that or there's something else in your system that's causing the issue. Is there a fuse between battery and the Victron MPPT? Double check that.@TallPaul_S
Plugged power bank into panels on van and result 47W incoming. This leads me to believe the Vic is not well?
oh, , . . . so it was connected up wrong before?The Vic is or has been connected to the battery fine for weeks and showing Volts/state just no PV . There is a fuse which is fine . I think this all stems back to when I first fitted the Vic and mixed up the cables between PV and Batt so the PV had Batt connected , that gave issues with the 30A fuse blowing until I realised my dumbassery .
that video just details the fact that the victron mppt will wait for a PV voltage of 5v over the battery voltage before switching on,@Dellmassive - your shed hasn’t got a split charger like a van requires.
The settings for mine detects if the engine is on and references a minimum voltage or the panel will not work.
This video explains it.
But how can you test your kit is all working in the van?
@Dellmassiveoh, , . . . so it was connected up wrong before?
maybe its fried then?
very unusual for Victron, but possible,
they always say to connect the battery before PV to prevent any damage.
the new unit will be a good test - roll on tomorrows delivery.
