New strut top mount bearing assemblies and drop links - Are genuine VW ones best?
qwertyuiop7
Fitting some new coilovers to the camper, going to replace the drop links and the strut top mount bearing assembly at the same time. For the top mounts is it best to just replace them with the genuine Volkswagen ones as fitted from new? Or are some of the 'uprated' ones from either Bilstein or Meyle a better bet?
Also do I need to replace all three bits of the top mount (bearing, rubber and cast mounting plate) or am I okay just doing the rubbers and the bearings as i can't see how the cast mounting plate can wear out ? or can it?
Same for drop links, are VW's best on a 60mm lowered van or are there better options?
Cost isn't really an issue for either I just want to fit the best and fit them once, but saying that i don't want to waste cash on bits i dont really need.
Thanks for your help
I went with Meyle HD for both.
Haven't done enough miles to prove whether they are any 'better'.
The only reason to replace the ally plate is if you have a T5 or T5.1. VW don’t supply these top bearings any more. , they supply the bearing, top mount, and plate as a T6 conversion , the bearing is much bigger and stronger. , we only use the genuine parts from VW. As they last better in our Opinion get some new rear spring rubbers you will need them , while you are busy do the drop links they are troublesome
Meyle HD top bearing full set bought in 2020. Now replaced them in 2024. They give warranty 4 years . Realized they faulty after spring started jumping on full lock. As you see on left is old generation of Meyle Hd and on right is new improved generation. They are bigger now. Genuine ones are bigger too. Van lowered 40mm and has 255/40/20 tyres in front. In 4 years done about 60k
I had some MEYLE top mount bearings as I got them from a friend for free, Replaced some old genuine ones when replacing the suspension.
Have found they didn't last very long before failing again, so gone back to genuine top mounts with no issues since.
Drop links wise, I use genuine ones through ease.. as I get them cheap through work. But I know people have recommended the lemforder drop links in previous threads.
