@Goldy fitting under the right side (OEM position) and 'plumbing' the hot air to the left side is a thing that I did on one conversion BUT it was a lot of work. I had to remove and modify the heat shield above the exhaust and create a path for the hot air tube with insulation to retain the heat. At that length of tube and with the bends necessary it is approaching the limit of the permissible flow restriction of the heater, I ended up using a tube size larger than normal for a 2.2kW heater.
As for drilling the floor (tank cutter job) it's easy enough if you take the obvious precautions around existing wiring loom(s) etc. and treat the cut edges appropriately to stop corrosion in the future.
Personally I would install the heater in the OEM position under the floor below the right front seat (UK driver's) and bring the outlet out in the base of that seat. I know it eats some useful space but is easier to install and gives a better hot air flow.
