No brake light t6 transporter 2018 no warning light on dash
H gordy
Hi all has anyone had jo brake lights and no warning light on dash board every thing possible has been checked fuses bulbs brake switch etc
You can check/test at the midway conection block under the passenger seat.
Has the bulb warning dash light been switched off by VCDS. Some people, including me, have done this when fitting LED DRL bulbs in H7 units following upgrade from H4's.
I think i went off when the electrician fitted a fuse that fixed the front and back side lights and interior door lights, but the brake lights still not working , that’s why Dont understand it going away from dash
Either disconnect the vehicle battery or leave it (locked) for a few hours to see if the BCM resets now that fuse has been replaced.
