Northeast - suspension specialist
Gringo73
Wondered if anyone could recommend a descent Garage in the North East ideally,or North West that sells and installs Bilstein B14 set ups or Koni coil overs.
Looking to drop the T32 by 40mm for a better drive/comfort.
Cheers in advance.
A lot of things we do are long term projects so to slip suspension installs in is easy . can accommodate you at short notice
Stock is the main issue we need to be sure what ever you want is available .
Yes we are , the factory told me a few weeks ago when I was there visiting that they are pushing Transporter parts through quicker for me
Ill up date stock asap
can anyone recommend a garage in the Gateshead area to fit some H&R anti roll bars? and any idea what sort of price i am looking at for fitting?
Hi dont know if your sorted yet but you could try AF Motor Services in Durham he does a load of work on Transporters - ask for Alex
Thanks Tonto, i've had a quote of £140 from BTG performance (north tyneside). they also do Revo remaps. Another garage quoted me £250 for fitting which i thought was high
BTG are good guys.
I'm looking for a garage in the north east to fit a set of coil overs (likely B14s). I'm based in Blyth in Northumberland so North of Newcastle preferred.
There is a local VW specialist here in Blyth called Volkcentre who can supply and fit however I have never used them.
Does anyone have any recommendations?
Try Swift motor engineers they do all work on my T6 Swift Motor Engineering | Independent VW Audi repairs in Newcastle
Based in Westerhope Newcastle might be a bit out for you but I highly recommend them.
Hi everyone
After a bit help I’m due new tyres and I’m convinced rear of van is toeing so want to go somewhere who can fit new tyres and adjust toe and possibly fit the poly flex adjustable bushes so to alter the camber as that looks a long way out when I stand looking down at wheels it really irritates me, I have stance+ fitted quite low but thinking to raise by 10-15mm.
So I want to go somewhere that actually works on t6 and understands what I need/want rather than normal garage where I will have to explain things like NO LOAD settings on hunter laser alignment
Any recommendations or advice appreciated
I’m in between Sunderland Durham area
Paul
