Not coded to RH drive
huw169
Black 199 Shuttle
For some reason my RH drive van is not coded for RH drive.
I've not coded it yet, but will it make a difference, and why wouldn’t it be coded as RH drive?
The descriptions for the codings are not 100% accurate. I would be cautious before making "random" coding chances of factory settings - if it's not broken, do not fix it ;)
I have noticed the same "RHD discrepancy" on many scans found here.
The descriptions come from label file 04L-907-309-V2.lbl which actually was an ECU made by Bosch - ours is made by Delphi. Certainly VW has kept tried to keep them compatible but everything was not probably transferred or (used any more). Also worth to note that your engine CXEC is equipped with latest software (WLTP version) and it was not even supported for a while by VCDS. Finally the support was brought using label file of old ones.
