Hi all, immediately after getting my EGR mapped out and physically deleted, I drove 100 motorway miles with no issue.
On the very next trip, I was about 30 miles up the road (motorway) when the EML came on and so I stopped to do a check. Output:
Glow plug has been reported for about a year now, was going to sort that after having EGR delete. NOX error is a first though, haven't seen that in my ownership.
I will clear the code and report back on my next trip. Meanwhile, any thoughts?
Code:
P20EE [0x20EE]
Nitrogen oxide (NOx) sensor, catalyst, bank 1 - efficiency below threshold
Status: Confirmed
P0674 [0x0674]
Glow plug, cylinder 4 - circuit malfunction
Status: Pending
19. CAN Gateway
No DTC found.
09. Onboard supply control unit09. Onboard supply control unit
DTCs: 1
03303 [0x0CE7]
Status: Test is inhibited by other DTC, Validated and stored in non volatile memory
02. Transmission control unit
No DTC found.
03. ABS control unit
No DTC found.
01. Engine control unit01. Engine control unit
DTCs: 2
15922 [0x003E32]
P067400: Cylinder 4 Glow Plug Circuit
Status: Test failed, Test failed (current drive cycle), Pending, Test failed since last DTC clear
31103 [0x00797F]
P20EE00: SCR NOx Catalyst Efficiency Below Threshold Bank 1 Catalyst 1
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear, Warning indicator requested
08. Heater and climate08. Heater and climate
DTCs: 1
9470993 [0x908411] Archive (inactive)
Status: Confirmed
0D. Slide Door Left (VW TP2.0)
No DTC found.
10. Parking Assistant 2
No DTC found.
13. Active cruise control
No DTC found.
15. SRS
No DTC found.
17. Dashboard
No DTC found.
18. Additional heater
No DTC found.
20. FLA
No DTC found.
25. Immobilizer
No DTC found.
36. Driver seat adjustment
No DTC found.
5F. Electronic Information System 15F. Electronic Information System 1
DTCs: 7
01555 [0x000613]
B201A00: Checking software version management
Check software version management
Status: Test failed, Confirmed
00512 [0x000200]
B13A001: Speaker channel 1, Electrical error
Bass speaker, channel 1, open circuit (DC diagnostics)
00517 [0x000205]
B13A101: Speaker channel 2, Electrical error
Bass speaker, channel 2, open circuit (DC diagnostics)
00518 [0x000206]
Treble speaker, channel 2, open circuit (AC diagnostics)
00522 [0x00020A]
B13A201: Speaker channel 3, Electrical error
Bass speaker, channel 3, open circuit (DC diagnostics)
00523 [0x00020B]
Treble speaker, channel 3, open circuit (AC diagnostics)
00527 [0x00020F]
B13A301: Speaker channel 4, Electrical error
Bass speaker, channel 4, open circuit (DC diagnostics)
61. Battery Regulation using CAN (VW TP2.0)
No DTC found.
62. Rear left door electoronics (VW TP2.0)
No DTC found.
69. Trailer functions
No DTC found.
72. Rear right door electronics (VW TP2.0)
No DTC found.
76. Parking assistant
No DTC found.
78. Slide Door Right (VW TP2.0)
No DTC found.
