Ocean lowering: B8 shocks or B14 coilovers?
I'm probably going to have the super stiff ARBs fit in a few weeks once I have the funds. I like the ride of the B14s and Ifni can get it more neutral or even oversteering I'd be very chuffed.
Can someone explain about the LED self leveling kit?
I have LEDs on my highline and ARBs now so I assume as the van rolls and sways now, well I know it does! So how does the headlights self level now and why would I need a new self leveling kit? Especially if I will have hopefully less body roll?
Mounted on the rear anti roll bar is a self leveling sensor for the led headlights. Nothing major you just need the correct ARB kit as it comes with the additional bracket.
As above, it’s the way the rear level sensor mounts as it straddles the ARB and is fixed on the same horsehorse clamp that holds the ARB in place so you just need to make sure you order the correct ARB or you won’t be able to remount the rear level sensor
