OEM Brake Disc Size?
T6180
T6 Legend
Is there a way without taking any wheel off as I'm working away this week to find out what size my discs are? I've provide my registration number and I've been told there are two different sizes for my model of vehicle...
As you know @T6180 I have the same van, and mine needed the larger brakes. I believe they are 340mm.
Take a look and you will see, (compared to this >) (on 18" rims)
These are the large fronts 340mm,
and these are the standard rears 294mm,
Brakes:
Pads:
308mm Pagid Brake Pad (Front Axle) Product Code: 101441298
340mm Pagid Pagid Brake Pad (Front Axle)Product Code: 101441868
294mm Pagid Brake Pad (Rear Axle) Product Code: 101441318
Discs:
Smaller 308mm Front: Pagid Brake Disc (Front Axle)Product Code: 104441288
larger 340mm front; Pagid Brake Disc (Front Axle)Product Code: 104442118
standard 294mm rears: Pagid Brake Disc (Rear Axle)Product Code: 104441368
Wasn't I fast enough for you :whistle:
