Im thinking a bit too low!..Looks good, how low did you go?
Was 75mm drop from original, front and rearVery nice doing mine next week how much drop you had ?
That's exactly the same as mine, also on Devonports, but it was only about 55/50 mm drop from its original height! Just shows how much the ride heights of standard vans can vary. I hate the tip up of the rear though and want mine bringing down level as most of the weight in my van is carried midships so the rear doesn't need to allow for it.Im thinking a bit too low!..
Front 385, rear 400
Mine is a T32 what's yours, I might lift the front a little when I get alignment checked in a few weeksThat's exactly the same as mine, also on Devonports, but it was only about 55/50 mm drop from its original height! Just shows how much the ride heights of standard vans can vary. I hate the tip up of the rear though and want mine bringing down level as most of the weight in my van is carried midships so the rear doesn't need to allow for it.
T28. I'm going the other way and have the rear dropped to the same height as the front.Mine is a T32 what's yours, I might lift the front a little when I get alignment checked in a few weeks
