Over the moon with the SoLow -45mm Eibach spring set.
J3AAY
Just thought I’d post as I was unable to find almost nothing on these springs.
I’ve got a T32 which is not worked, but used as a big car. The most weight it gets is when camping with the family.
Now a full set of shocks and springs would always be best, but like most I had a budget and had always been happy with my previous vans on dealer fitted Eibach Sportline springs (-30mm).
I saw these as a kit at ~£260 and jumped at it (thanks for eBay’s discounts / voucher codes).
The ride is just like the Sportlines, but it’s marginally lower. I really like it. PSA before and after side shots.
It’s still got to settle, and I’ve got to get the 4- wheel alignment done, but you get the idea.
Highly recommended for anyone wanted a modest drop on a budget
How have you found the ride quality? I'm stuck in analysis paralysis between the SoLow -45mm and the H&R springs -40mm... Or save up for the B14s.
I've got a T6 multivan on 19s which is a bit heavier than the transporter. It will be used as a basic camper, so I don't want to go too low but your drop looks perfect.
Sorry mate, just seen this. Ride is lovely, obviously had them on some time now. Also done some fully laden runs to the tip and no issues.
did you use the dampeners you had already on these @J3AAY ? I've got a 67plate t30 which has 20's on it and want to both reduce the height and improve the feel/bounce. I appreciate ideal would be doing springs and shocks but budget is limited and these looked good to my simple brain
I used the original dampers. No issues at all. Rides lovely
