Good evening, it might not be related but since having some work recently (gearbox out) I am getting this fault. It is very intermittent and sometimes doesn't occur for a while but other times it will being on the EML.
I have checked the pipework to the differential pressure sensor and that seems ok.
I disconnected at the Cat and applied a little pressure to see the sensor reading change and there didn't appear to be any leaks.
However what I have noticed is that when I'm driving the 'Particle Filter, diff pressure Sensor 1 bank 1' (which I assume is the pre DPF sensor) reads approx 20-100mbar but when I'm at idle this drops to around 1mbar which is less than Sensor 2 (I assume post DPF). Surely the pressure can not be less before the DPF than after?
Maybe I am missing something?
This is at idle:
And driving:
This is at idle:
And driving:
