Parking Heater Won’t Turn On.
SimonTDK
Hi guys.
So the recent couple of days I’ve had an issue with my parking heater. When ever I’m trying to, either manually or via timer, start the heater it won’t turn on. The symbol in my display just comes on for a second or two, and then disappears.
Any good advise?
Car is of course filled with diesel, and I’ve tried with engine running also.
Best regards
Simon
Hi guys.
Any good advise?
Best regards
Simon
Which heater - a sticker on driver door? Does ventilation mode work? Do you have also a remote? Which model year? How many miles/kilometers driven? Typical driving distance - just trying to estimate how many startups there have been? Has the van been parked in incline (nose down) with low fuel (less than quarter in tank) when trying to fire up the heater? Any chance to read fault codes?
Parking heater runs just fine at any temperature - at least below +20C anyways.
heater is a webasto Thermo Top Evo, with part number 5Q0.010.014.D
Car is a 2017 Caravelle with 35.000km on the clock.
Ventilation mode, don´t work either.
Typical driving distance is 12-15 to/from work on a daily basis, and longer trips in the weekends.
My driveway is at a slight incline.
I´ve had VCDS on the car, and I have a fault in 18 - Parking heater, but my VCDS is in Danish.
So don´t know how much info that will give you, i´m currently also running the same thread in a danish vw forum.
Part number 5Q0.010.014.D is a part number for a door sticker only and not for your heater;)
Please post your faults from VCDS here.
We all know how Google translator works;)
Reactions: mmi
ohhh then i learned something to day :D
Well here comes the vcds fault code, that i "pulled" out of the car this morning.
And thanks in advance, for all your help and inputs there much appreciated
Code:
Torsdag,26,Marts,2020,06:13:22:44529
VCDS -- Windows baseret VAG/VAS emulator - Kører på Windows 8 x64
VCDS version: NEZ 19.6.2.1  HEX-V2 CB: 0.4508.4
Dataversion: 20200324 DS310.0
www.vcds.dk
Stelnummer: WV2ZZZ7HZHH136719   Indreg.nr.: CB85921
Kørestrækning: 34440km   Reparationsordre:
Modeltype: 7H-VN75 (7E0)
Søgt på: 01 02 03 04 08 09 10 13 15 17 18 19 25 5F 61 69 6E 0B
Stelnummer: WV2ZZZ7HZHH136719   Kørestrækning: 34440km
01-Motor -- Status: Ok 0000
02-Automatik -- Status: Ok 0000
03-ABS bremser -- Status: Fejlfunktion 0010
04-Styrevinkel -- Status: Ok 0000
08-Klimaanlæg -- Status: Ok 0000
09-Centralelektrik -- Status: Fejlfunktion 0010
10-Park.assist. -- Status: Ok 0000
13-Afstandsreg. I -- Status: Ok 0000
15-Airbags -- Status: Ok 0000
17-Instrument -- Status: Ok 0000
18-Parkeringsvarme -- Status: Fejlfunktion 0010
19-CAN Gateway -- Status: Ok 0000
25-Startspærre -- Status: Ok 0000
5F-Informationselek. -- Status: Ok 0000
61-Batteriregulering -- Status: Ok 0000
69-Anhængertræk -- Status: Ok 0000
6E-Betjening tag -- Status: Fejlfunktion 0010
Styreenhed  01: Motor (2D2D2-CXFA)     Forklaringsfil:. NEZ\04L-907-309-V2.clb
   Styreenhedsnr: SW: 04L 906 056 KH    HW: 04L 907 445
   Komponent    : R4 2.0l TDI   H02 6184
   Revision    : 23002001
   Kodning    : 0025401C436401080000
   Forhandler    : WSC 02737 790 50316
   ASAM datasæt    : EV_ECM20TDI03004L906056KH 004013
   ROD: EV_ECM20TDI03004L906056KF.rod
   VCID: 7DA7F8893D7BB1FFA20-8028
1 fejl fundet:
27277 - Spændingsforsyning
          P0562 00 [032] - Spænding for lav
          Periodisk - Ikke bekræftet - Testet siden sletning af hukommelse
Readiness: Ikke tilg.
Styreenhed  02: Automatik (J743)     Forklaringsfil:. NEZ\0BH-927-711.clb
   Styreenhedsnr: SW: 0BT 300 046 J    HW: 0BH 927 711 G
   Komponent    : DSG DQ500-7F  H11 5301
   Revision    : 00H11V01
   Kodning    : 0014
   Forhandler    : WSC 00000 000 00000
   ASAM datasæt    : EV_TCMDQ500021 001001
   ROD: EV_TCMDQ500021_VW36.rod
   VCID: 3D2738897DFB71FFE20-8068
Ingen fejlkoder fundet.
Styreenhed  03: ABS bremser (J104)     Forklaringsfil: NEZ\7E0-907-37x-MK100ESC.clb
   Styreenhedsnr: SW: 7E0 907 379 Q    HW: 7E0 907 379 N
   Komponent    : ESC           H06 0133
   Revision    : 00000000    Serienummer    : 40487000000602
   Kodning    : 347E4098256584842C7C0277A48B21D378F700
   Forhandler    : WSC 02739 790 50316
   ASAM datasæt    : EV_Brake1ESCCONTIVN75XGP2 011001
   ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
   VCID: 40D9417D0A091C17896-8014
1 fejl fundet:
0397 - Dæktryksadvarsel
          C102D F0 [008] - Tryktab
          Periodisk - Bekræftet - Testet siden sletning af hukommelse
             Fryserammedata:
                    Fejl status  : 00000001
                    Fejlprioritet: 3
                    Fejlhyppighed: 2
                    Nulstiltæller: 86
                    Kørestrækning: 26912 km
                    Dato: 2019.10.19
                    Tid: 10:16:34
Styreenhed  04: Styrevinkel (G085)     Forklaringsfil:* NEZ\6R0-959-654.clb
   Styreenhedsnr: SW: 6R0 959 654     HW: 6R0 959 654
   Komponent    : LENKW.SENSOR  H07 0070
   Serienummer    : 17021713470770
   Kodning    : 01
   ASAM datasæt    : EV_LWSKLOVW25X 005001
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5FF85307DAAE7BBA-802A
Styreenhed  08: Klimaanlæg (J255)     Forklaringsfil:| NEZ\7E5-907-040.clb
   Styreenhedsnr: SW: 7E0 907 040 T    HW: 7E0 907 040 T
   Komponent    : ClimatronicT5 H04 0510
   Revision    : 00001K04
   Kodning    : 0000000103
   ASAM datasæt    : EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis.rod
   VCID: 34311DAD4EB1B0B71DE-8060
   Slave 1:
   Undersystem 1 - Styreenhedsnr: SW: 7E5 907 049 C    HW: 7E5 907 049 C
   Komponent    : Heckbedienung  H11 0303
   Serienummer    : BHB-0011702170015024
Styreenhed  09: Centralelektrik (J519)     Forklaringsfil:. NEZ\7E0-937-BCM-V1.clb
   Styreenhedsnr: SW: 7E0 937 090 B    HW: 7E0 937 090
   Komponent    : BCM PQ25 Max4 H81 0744
   Revision    : B9081001    Serienummer    : 0982 052170914
   Kodning    : 7AF8793A0A21201201284F746CEB8ED40F94690F60CC6960320400A30840
   Forhandler    : WSC 02737 022 109841
   VCID: 2A0D03D59CF5F647B72-807E
   Undersystem 1 - Styreenhedsnr:: 5K7 955 559 C  Forklaringsfil: NEZ\5K7-955-559.CLB
   Komponent    : RLS 150217 04  42  0106
   Kodning    : 0228DD
   Undersystem 2 - Styreenhedsnr: SW: 7E0 959 801 M    HW: 7E0 959 801 M
   Komponent    : J386__TSG_FT  003 0653
   Serienummer    : KU0KU023021770547067
   Kodning    : 0400A0
   Undersystem 3 - Styreenhedsnr: SW: 7E0 959 802 M    HW: 7E0 959 802 M
   Komponent    : J387__TSG_BT  003 0653
   Serienummer    : KU0KU023021770543551
   Kodning    : 1400A0
   Undersystem 4 - Styreenhedsnr: SW: 7E0 959 442 A    HW: 7E0 959 442 A
   Komponent    : E221__MFL-DC1  H02 0103
   Serienummer    : 29170000386560077065
   Kodning    : B4FFFF
2 fejlkoder fundet:
01495 - Pære for venstre fjernlys (M30)
            010 - Afbrydelse/Kortslutning til plus
             Fryserammedata:
                    Fejl status  : 01101010
                    Fejlprioritet: 3
                    Fejlhyppighed: 1
                    Nulstiltæller: 7
                    Kørestrækning: 31902 km
                    Tidsindikation: 0
                    Dato: 2020.01.17
                    Tid: 11:12:22
01499 - Pære for højre fjernlys (M32)
             Fryserammedata:
                    Fejlprioritet: 3
                    Fejlhyppighed: 1
                    Nulstiltæller: 7
                    Kørestrækning: 0 km
                    Tidsindikation: 0
                    Dato: 2020.01.17
                    Tid: 11:18:22
Styreenhed  10: Park.assist. (J446)     Forklaringsfil:| NEZ\7E0-919-475.clb
   Styreenhedsnr: SW: 7E0 919 475 AA    HW: 7N0 919 475
   Komponent    : PARKHILFE 8K  H06 0212
   Revision    : --------    Serienummer    : 28231701001769
   Kodning    : 11810C
   ASAM datasæt    : EV_VW75XParkAssis8K 001012
   ROD: EV_VW75XParkAssis8K_001_VN75.rod
   VCID: 71BFD4B97123C59F368-8024
Styreenhed  13: Afstandsreg. I (J428)     Forklaringsfil:| NEZ\7N0-907-572.clb
   Styreenhedsnr: SW: 7N0 907 572 C    HW: 7E0 907 572
   Komponent    : ACC Bosch PQx H03 0211
   Serienummer    : 19021704381551
   Kodning    : 00005000FE0779
   Forhandler    : WSC 01383 790 50316
   ASAM datasæt    : EV_ACCBEGVW361 001006
   ROD: EV_ACCBEGVW361_VW32.rod
   VCID: 363527A558CDA2A723A-8062
Styreenhed  15: Airbags (J234)     Forklaringsfil:* NEZ\5K0-959-655.clb
   Styreenhedsnr: SW: 7E0 959 655 H    HW: 7E0 959 655 H
   Komponent    : VW10Airbag01R H08 0018
   Revision    : --------    Serienummer    : 003V4002AT92
   Kodning    : 000000000000000000000000000000003152
   Forhandler    : WSC 02734 790 50316
   ASAM datasæt    : EV_AirbaVW10BPAVW12X 001028
   ROD: EV_AirbaVW10BPAVN750_VW12.rod
   VCID: 3B23369163EF7FCFDC4-806E
   Crashsensor til sideairbag i førerside:
   Serienummer    : 3495ZRB400859874E8J8
   Crashsensor til sideairbag i passagerside:
   Serienummer    : 3505ZRB400G599BK7937
Styreenhed  17: Instrument (J285)     Forklaringsfil:| NEZ\5K0-920-xxx-17.clb-SRI1
   Styreenhedsnr: SW: 7E0 920 870 S    HW: 7E0 920 870 S
   Komponent    : KOMBI         H03 1104
   Serienummer    : 00000000000000
   Kodning    : 140F010300
   ASAM datasæt    : EV_Kombi_UDS_VDD_RM09 A05733
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
   VCID: 392F2C9969D34DDFCE8-806C
Styreenhed  18: Parkeringsvarme (J364)     Forklaringsfil:| NEZ\7E0-963-27X-18.clb
   Styreenhedsnr: SW: 7E0 963 272 B    HW: 7E0 963 272 B
   Komponent    : STH-T5GP2     003 0009
   Kodning    : 4401
   ASAM datasæt    : EV_AuxilParkiHeateWOST5G2 001013
   ROD: EV_AuxilParkiHeateWOST5G2.rod
   VCID: 2B0306D1938FEF4F4C4-807E
3 fejlkoder fundet:
0005 - Gløderør med flammeovervågning
          B1385 1B [009] - Modstand for høj
             Fryserammedata:
                    Fejlprioritet: 3
                    Fejlhyppighed: 2
                    Nulstiltæller: 103
                    Kørestrækning: 33665 km
                    Dato: 2020.03.04
                    Tid: 07:55:06
                    Parkeringsvarme: driftstilstand: Efterløb – Udbrænding
                    71
                    Parkeringsvarmer kølevæsketemperatur: 58 °C
                    Kølevæsketemperatur: 56 °C
                    Status motorgang: Ikke registreret
                    Tankindhold: 18 l
                    Varmeydelse: 0 W
0036 - Brændstofniveau for lavt
          P1250 00 [008] - -
             Fryserammedata:
                    Fejlprioritet: 7
                    Fejlhyppighed: 4
                    Nulstiltæller: 141
                    Kørestrækning: 34285 km
                    Dato: 2020.03.20
                    Tid: 04:15:09
                    Parkeringsvarme: driftstilstand: Start
                    80
                    Parkeringsvarmer kølevæsketemperatur: 33 °C
                    Kølevæsketemperatur: 24 °C
                    Status motorgang: Registreret
                    Tankindhold: 13 l
                    Varmeydelse: 5000 W
0135 - Varmeapparat er låst
          B138F 00 [009] - -
             Fryserammedata:
                    Fejlprioritet: 2
                    Fejlhyppighed: 1
                    Nulstiltæller: 103
                    Kørestrækning: 34402 km
                    Dato: 2020.03.25
                    Tid: 12:10:12
                    71
                    Parkeringsvarmer kølevæsketemperatur: 27 °C
                    Kølevæsketemperatur: 52 °C
                    Tankindhold: 66 l
                    Varmeydelse: 0 W
Styreenhed  19: CAN Gateway (J533)     Forklaringsfil:. NEZ\7E0-909-901.clb
   Styreenhedsnr: SW: 7E0 909 901     HW: 7E0 937 090
   Komponent    : GW-K-CAN TP20 H81 0744
   Revision    : B9081001
   Kodning    : 042205
   VCID: 6889B9DD42790457616-803C
Styreenhed  25: Startspærre (J334)     Forklaringsfil:| NEZ\5K0-920-xxx-25.clb
   Styreenhedsnr: SW: 5K0 953 234     HW: 5K0 953 234
   Komponent    : IMMO          H03 1104
   Serienummer    :
   Kodning    : 000000
   ASAM datasæt    : EV_Immo_UDS_VDD_RM09 A03710
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8DC3D55CF53647772-803E
Styreenhed  5F: Informationselek. (J794)     Forklaringsfil:| NEZ\5G0-035-MIB-ENT2.clb
   Styreenhedsnr: SW: 1K8 035 150 H    HW: 1K8 035 150 H
   Komponent    : MU-E--ER      055 7085
   Serienummer    : 12011700013253
   Kodning    : 06570000BE00000041110001000000001F0000C40000010001
   ASAM datasæt    : EV_MUEnt4CGen2LGE 001032
   ROD: EV_MUEnt4CGen2LGE_VW12.rod
   VCID: 2A0D03D59C75F647B72-807E
Styreenhed  61: Batteriregulering (J840)     Forklaringsfil:. NEZ\1K0-907-534.clb
   Styreenhedsnr: SW: 7E0 907 534     HW: 7E0 937 090
   Komponent    : Batt.regelung H81 0744
   Kodning    : 330B1A73
   Forhandler    : WSC 02739 790 00000
   Undersystem 1 - Styreenhedsnr: SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Komponent    : J367-BDMConti  H03 1050
   Serienummer    : 75885700001702100662
Styreenhed  69: Anhængertræk      Forklaringsfil:. NEZ\1K0-907-383-V2.lbl
   Styreenhedsnr: SW: 1K0 907 383 F    HW: 1K0 907 383 F
   VCID: 303911BDBA298C97796-8064
Ingen fejlkoder fundet!
  eller fejlkoder ikke understøttet af styreenhed
  eller kommunikationsfejl opstået
Styreenhed  6E: Betjening tag (J702)     Forklaringsfil:. NEZ\7E5-919-037-W2.clb
   Styreenhedsnr: SW: 7E5 919 037 G    HW: 7E5 919 037 G
   Komponent    : Dachdisplay   H15 0200
   Revision    : 10100012    Serienummer    : 475807
   Kodning    : 000102
   Forhandler    : WSC 02759 790 00000
   VCID: 353720A9454BA9BF2A0-8060
1 fejl fundet:
01207 - Styreenhed til ekstra varmeanlæg (J364)
            008 - Urealistisk signal - Periodisk
             Fryserammedata:
                    Fejl status  : 00111000
                    Fejlprioritet: 3
                    Fejlhyppighed: 2
                    Nulstiltæller: 144
                    Tidsindikation: 0
                    Dato: 2020.03.20
                    Tid: 04:16:19
Slutning-(Forløbet tid: 02:15, VBat. start/slut: 11.9V/11.8V. VIgn 11.8V)--
Torsdag,26,Marts,2020,06:30:26:44529
www.vcds.dk
03-ABS bremser -- Status: Ok 0000
09-Centralelektrik -- Status: Ok 0000
6E-Betjening tag -- Status: Ok 0000
   Revision    : 23002001
   Revision    : 00H11V01
   Kodning    : 0014
   Kodning    : 01
   Revision    : 00001K04
   Slave 1:
   Kodning    : 0228DD
   Kodning    : 0400A0
   Kodning    : 1400A0
   Kodning    : B4FFFF
   Kodning    : 11810C
   Kodning    : 4401
3 fejlkoder fundet:
             Fryserammedata:
                    Fejlprioritet: 3
                    Fejlhyppighed: 2
                    Nulstiltæller: 103
                    Dato: 2020.03.04
                    Tid: 07:55:06
                    71
                    Tankindhold: 18 l
                    Varmeydelse: 0 W
          P1250 00 [008] - -
             Fryserammedata:
                    Fejlprioritet: 7
                    Fejlhyppighed: 4
                    Nulstiltæller: 141
                    Dato: 2020.03.20
                    Tid: 04:15:09
                    80
                    Tankindhold: 13 l
                    Varmeydelse: 5000 W
          B138F 00 [009] - -
             Fryserammedata:
                    Fejlprioritet: 2
                    Fejlhyppighed: 1
                    Nulstiltæller: 103
                    Dato: 2020.03.25
                    Tid: 12:10:12
                    71
                    Tankindhold: 66 l
                    Varmeydelse: 0 W
   Revision    : B9081001
   Kodning    : 042205
   Serienummer    :
   Kodning    : 000000
   Kodning    : 330B1A73
Styreenhed  69: Anhængertræk      Forklaringsfil: NEZ\1K0-907-383-V1.lbl
   Styreenhedsnr: SW: 1K0 907 383     HW: 1K0 907 3
   Komponent    : AnF  H12 0130010haenger0
   VCID: 6A8DC3D55C753647772-803E
   Kodning    : 000102
Slutning-(Forløbet tid: 02:12, VBat. start/slut: 11.6V/11.5V. VIgn 11.5V)--
Danish doesn't seem to be a problem - and the actual fault codes are still the same ;)
Glowplug flame monitoring-
Resistance too high.
B138F 00 [009] - -
Heater is locked.
I think it's obvious that it won't turn on because of failed glow plug.
So a new glowplug, and then unlock the heater ?
I´m still a new user of vcds, so still learning about the program :)
This should unlock the heater.
There is also a basic setting for glow plug replacement - shouldn't hurt to run after replacing the glow plug.
Will this unit do the trick ?
Brænder inkl. glødestift
No need to replace the burner tube - just replace the glow pin. Part number 1315949B like this one Thermo Top Evo Glow pin 12v | 1315949A You can buy them from China dirt cheap exactly the same as OEM pins. Ebay if you can get a German retailer to ship ( including gaskets Webasto Glühstift für Standheizung Thermo Top Evo 4,5 oder 5+ inkl. Dichtung 12V | eBay)( No Danish Ebay? ) You should have Webasto dealers in Denmark.
Hey Guys.
I’ve got to do the work by switching the faulting glow plug :rolleyes:
But luckily I’m now between jobs, and have the time to do. The new plug have been on my shelf for to long now. Before I do the jobs, I wanted to ask for any good advices before doing the task.
