wheelbarrow
So I bought the OE retrofit kit PDC from vagtec and also 1K8919472A upgrade kit from carsystems.eu.
This is the retrofit kit I bought:
And this is the module upgrade kit:
The issue I am having is that the pinouts on the upgrade module adaptor cable does not match the vag-tec loom pinouts. Not only this, but the cable colours do not match either.
Example of what I mean:
Big connector on the adaptor side (10 pins):
Big connector on the loom Side (6 pins):
And you can see that the cable colours aren't all the same either.
This is similar this for the other 2 smaller connectors:
Small connector 1 - Adaptor side (8 pins):
Small connector 1 - loom side (6 pins):
Small Connector 2 - Adaptor Side (10 pins):
Small connector 2 - loom side (8 pins):
As you can see the pins don't line up and I can't infer from the cable colours which goes where...
I am a bit lost as to where I should look next. Does anyone have any ideas or suggestion as to what to look at now? Possibly a wiring diagram, but not sure where I would find these.
Another question:
On the main loom section, there is an unterminated red, brown and yellow cable. The brown is the negative, the red is switched live, but not sure where the yellow is supposed to go to?
Genuine VW OEM Retrofit Kit - Parking Sensors - Front & Rear - with Fog Lights - T6 Transporter | VAG-TEC E-shop
<p>The Volkswagen Transporter T6 Optical Parking System (OPS) Retrofit is the latest VW technology and it's brilliant. Using all genuine VW parts you wouldn't know the difference between this system and one fitted at factory once installed. Featuring flus
vagtec.co.uk
VW T6 - Adapter + Module 1K8919472A - Upgrade
www.carsystems.eu
Another question:
