Phantom Leisure Battery
  • Thread starter Thread starter Deleted member 76805
  • Start date Start date
Yes and I've contacted them. They say it was so long ago they don't have a record but they've been very helpful to be fair.
They would surely have a standard place they would install a LB ?
If not they could at least tell you the different locations where they have fitted them before?
How are these cabinets fitted? Glued? Dowel? Just wondering if the battery is in the void above the gas cabinet below the fuse cupboard. As shown here. Could that rear facia be pried off? Thanks
Possibly floor is removable in the cupboard above with the tambour door?
Seems a shame to take an axe to that pristine cupboard.
I'll check again, there didn't seem to be any tabs or holes to lift up the shelf in that cupboard. Thanks
That panel on my van is screwed through the edge with a corner trim covering the screws.
As frosty says I’d try to remove the base of the tambour cupboard.
I’m pretty sure that’s where it will be.
I think that I must have frightened him off by asking several times as to the name of the converter so that other members could help if they had a van from them.
Maybe someone has stolen a van and is trying to find a tracker?
